Ford 3000 hydraulic problem
/ Ford 3000 hydraulic problem #2
With the Draft/Position Control lever set in the Draft (downward) position, engine running, lower links full down, stand on the lower links, pick up the upper link and push it forward to compress the draft control spring. If nothing happens, you have a control valve issue. If the lower links raise, you should be good, or you have a control lever linkage issue.
2006 KENWORTH W900 T/A DAYCAB ROAD TRACTOR (A64276)
2006 KENWORTH W900...
Rotary SPOA9-200 Automotive Lift (A59228)
Rotary SPOA9-200...
2023 KUBOTA SVL 97-2 SKID STEER (A65053)
2023 KUBOTA SVL...
1000 GALLON POLY NURSE TANK (A64276)
1000 GALLON POLY...
2018 TAKEUCHI TL8 SKID STEER (A59914)
2018 TAKEUCHI TL8...
2012 CARGO CRAFT 24' T/A ENCLOSED TRAILER (A65643)
2012 CARGO CRAFT...
