Ford 3000 3-point not working
/ Ford 3000 3-point not working #21
Soundguy, After giving it some thought and considering my best options as I know them, I think I will add a fitting and a extra on/off valve and tee off present
factory set-up so that I can by-pass the original routing with the mechanical pump and have the option to run direct gravity feed with a 2-4 psi electric fuel pump
on the carburator feed line if needed and still be able to use the long about routing including the mechanical pump if this dosen't work out.
I think it will be fun to see if this works and if the results are as I hope/or not I will certainly give you that feedback.
Thanks Again....Joe Hoag
/ Ford 3000 3-point not working #22
now that I think about it, we had a ford industrial engine on a wood chipper here a few weeks back ( just sld it actually ).. I converted that one to a 2-4 psi electric pump.. key on.. etc.. and just made up my own fuel line and used an inline filter.. vs the old can / canister fuel fitler that had been on it. mechanical pump on that one was deffinately kaput...
2021 JOHN DEERE 410E SERIES II OFF ROAD DUMP TRUCK (A65053)
2021 JOHN DEERE...
CATERPILLAR CS44B SMOOTH DRUM ROLLER (A64279)
CATERPILLAR CS44B...
2019 Ford Explorer AWD SUV (A64557)
2019 Ford Explorer...
2021 Cub Cadet Ultima ZT1 50in. Zero Turn Mower (A64557)
2021 Cub Cadet...
2012 Peterbilt 337 S/A 16ft. Cab and Chassis Truck (A64194)
2012 Peterbilt 337...
Winchester Sign (A64557)
Winchester Sign...
