lilranch2001
Super Member
- Joined
- Nov 25, 2009
- Messages
- 9,138
- Tractor
- Bobcat CT 235
I cant really add any info on your 2n issue, and it seems you are on top of it, but I am interested in hearing about the 8n.
If it is just the wiring messed up, you can get a whole new harness for like $20:thumbsup:
Do you know what year it is?
Side mount distributor is a newer one
Does it have a sherman? That would be a lever on the side of the transmission just forward of the clutch pedal. It is a pretty desirable option:thumbsup:
And one more thing to add, if ya didnt know, the N's had a transmission driven PTO, so you need an over-running-coupler on the PTO. Otherwise, when you are mowing along and hit the clutch to stop, the momentum of the bushhog blades will continue to drive the tractor because the PTO is connected to the transmission. All the clutch does is disconnect the engine.
Good luck with your tractors, and we like pics too:thumbsup:
I never had an over running clutch on my 8N, the "push" was part of the charm of that tractor, and the "challenge" not to get yourself in trouble because of it!
:thumbsup:
:laughing:
