Ford 2000 timing
/ Ford 2000 timing #1
kennyl123
Pollock, LA
Ford 2000
Hi all, I need some advice on my ford 2000 I removed the front cover and changed the gasket and seal and water pump. I took blots out of fuel injector gear but didn't think I let it turn any but I put all back together and it wouldn't crank tore it back down to check timing and I cant get the camshaft gear and the camshaft drive gear marks to match up , Idid not fool with those gears what happened to it ? or how do I get it back in time . I really don't know how to tell if # 1 piston is tdc on power stoke. PLEASE HELP
/ Ford 2000 timing #2
this is a 3 cyl diesel 2000 or a 4 cyl diesel 2000?
guessing 3 cyl by you taking bolts out? right?
PORTA POTTY (A67714)
2001 Belshe Backhoe Trailer (A64194)
2001 Belshe...
2018 Ford Focus (A61574)
2018 Ford Focus...
2009 INTERNATIONAL 7600 6X4 T/A GARBAGE TRUCK (A66091)
2009 INTERNATIONAL...
2019 Caterpillar D6N LGP Crawler Tractor Dozer (A66734)
2019 Caterpillar...
2021 Unused Paladin MD60SC 5ft. Rotary Brush Cutter Tractor Attachment (A66734)
2021 Unused...
