Ford 2000 timing
/ Ford 2000 timing #1
kennyl123
Pollock, LA
Ford 2000
Hi all, I need some advice on my ford 2000 I removed the front cover and changed the gasket and seal and water pump. I took blots out of fuel injector gear but didn't think I let it turn any but I put all back together and it wouldn't crank tore it back down to check timing and I cant get the camshaft gear and the camshaft drive gear marks to match up , Idid not fool with those gears what happened to it ? or how do I get it back in time . I really don't know how to tell if # 1 piston is tdc on power stoke. PLEASE HELP
/ Ford 2000 timing #2
this is a 3 cyl diesel 2000 or a 4 cyl diesel 2000?
guessing 3 cyl by you taking bolts out? right?
Set of 2 Unused ST205/75R15 Radial Trailer Tires (A66734)
Set of 2 Unused...
2014 JCB 190T SKID STEER (A65056)
2014 JCB 190T SKID...
2003 FORD F-750 SUPER DUTY(INOPERABLE) (A67714)
2003 FORD F-750...
Unused 2023 Hustler Regener8r LM630 Hydraulic Chain Harrow Tractor Loader Attachment (A66734)
Unused 2023...
2001 INTERNATIONAL 4700 4X2 S/A UTILITY BODY TRUCK (A66091)
2001 INTERNATIONAL...
2017 CATERPILLAR 308E2 CR EXCAVATOR (A65056)
2017 CATERPILLAR...
