Ford 2000 help
/ Ford 2000 help #1
Lookingfirhelp
Ford 2000 1967
Hey friends, I purchased a 1967 ford 2000. Unfortunately I had it 2 hours when the motor seized. Im looking to see if anyone has a used one or any advice for getting mine rebuilt. Ty
/ Ford 2000 help #2
Sorry to hear. Was it lubrication (lack of oil) or overheat (water pump, loss of fluid) related?, did you check the dipstick and radiator before you bought? did it have low oil pressure light? analog temp gauge? it is not an easy thing to estimate without diagnosing the cause and it requires at least some partial disassembly. Are you able to wrench?
/ Ford 2000 help #3
You can pull the oil pan off to see if there's a bottom end problem. If it doesn't need machine work on the block it can be rebuilt without separating the motor from the tractor.
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A57024)
2022 NEW HOLLAND...
UNUSED FUTURE 32" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 32"...
KIVEL 48" MINI PALLET FORKS (A60430)
KIVEL 48" MINI...
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
2016 TEXT 26ft T/A Dovetail Flatbed Equipment Trailer (A59230)
2016 TEXT 26ft T/A...
CONIBEAR EQ CO HYD SEED SPREADER (A60430)
CONIBEAR EQ CO HYD...
