ford 1910 clutch problems
/ ford 1910 clutch problems #1
pete581
ford 1910
I have a ford 1910 tractor that when i try to engage the pto to operate the finish mower, it grinds while engaging, even at the lowest idle possible w/o stalling the tractor.Whats the problem and whats the fix? thanks inadvance.
/ ford 1910 clutch problems #2
You probably have a dual clutch and the pto clutch is either stuck or out of adjustment, If you don't have a service manual get one. It will show you how to adjust it. If you do a search in the N/H forum for dual clutch you will find some good info,
Bill
Thanks bill, it is a dual clutch, i know, but thats about all i know. I do have a shop manuel and it describes a adjustment through opening in the clutch housing, i guess what im asking is can i visually see if this adjustment is needed, while tractor is running and trying to engage pto? or just engaging the clutch enough to see problem?
/ ford 1910 clutch problems #4
When was the last time you used the pto. How much freeplay do you have in the clutch petal. Do you understand how a dual clutch works. Is this tractor new to you.
Bill
