Ford 1900 wont start...electrical?
/ Ford 1900 wont start...electrical? #21
Eric,
My suggestion at this point is to remove the starter entirely off the tractor and take it to closest auto part supply for a test. They can do that test for free and should take only a few minutes. Take a pic of the wires first before taking the starter off. Taking starter off the tractor should take but a few minutes as well.The solenoid coil is either functional or open caused by a short or fused due a short as well. There might be crud on the solenoid where it will not be able to move the plunger in or out with a good coil. Solenoid once operational and activated in starter acts as a switch (relay) to provide electrical juice to main winding. You can bypass solenoid and directly put juice on the starter winding to turn it on. it seems non of those suggestions by others have not worked so far. although they are all valid methodology. My guess is that there is an open in something caused by a short. Can do continuity check on solenoid coil and other to diagnose but you got to break the starter down more to basic parts. Auto part store can check both solenoid and starter winding on bench but beyond that it needs to be taken apart. I don't think you can hurt it any by disassembly and checking things out if part store is not able to spin it.
JC,
/ Ford 1900 wont start...electrical? #22
My nightly update...I tightend the small screw on the solenoid and cleaned the terminal its attached to. That didn't help anything. So, I grabbed a jumper cable hooked to the + battery terminal, then directly to the small terminal on the solenoid. This produces a lot of spark and the solenoid clicks but does not engage the starter. Hooking the jumper to the large lug gives a small spark, but the starter doesnt spin at all. This is all with the clutch pedal blocked down. What do we think?
Bill, regarding the replacement ignition switch I installed, I attempted to use that to start the tractor from the seat, just for kicks. Turning the key to the left and holding it heats the glow plugs as it should. Then turning to the right, past "ON", to "START" when I get to a certain point it will stay in the "START" position even when I take my hand off of it (just the same as it stays in the "ON" psotion when I take my hand off of it). Is this normal? I'm not sure if I'm turning it past where its intended to tunr to crank the motor over, and unfortunately I can't tell because I get no starter clicks or cranking using the key. Also, when I turn the key to the "ON" position, the light that comes on in tach is the same light as the glow plugs. Shouldn't the other light for the battery be coming on?Thanks,Eric
The key should not stay in the start position. When the key is in the start position it is also powering the glow plugs. My glow plug light is not in the tach. The lights in the tach are oil pressure and volts. The glow plg indicator is a silver circle about the size of a quarter to the right of the steering colonm. It is not realy a light. It is a coil the gets red hot indicating the glow plugs are hot.
Bill
Eric,
JC,
Thanks JC. Pulling the starter/solenoid seems a good option at this point. As soon as I have a moment to pull it, I'll bring them down to NAPA for a bench test.
Bill
I didn't think it should stay in the start position. It must be either the oil pressure or voltage light on the dash coming on. I do have the glow plug indicator on the right side of the dash that glows orange when current runs through it when the plugs are juiced. That's working properly.
Thank you all for your patience and advice as we work through this. We'll get this thing running eventually! I'll post another update once I get the starter tested.
Eric
Good Morning All,
Here's an update. I pulled the starter solenoid and brought it to an Auto Electric shop near my work. He replaced solenoid, replaced the brushes, cleaned armature (which a mud wasp had built a nest around), new lugs and hardware, coat of paint. It looks great. And more importantly, the starter now works...but the tractor isn't running... yet. I re-installed the starter tried the key, and got nothing. So, I ran a jumper from the + battery terminal to the + lug on the starter because I'm still suspect of the battery lead and haven't had a chance to replace it (although juice is getting through to the glow plugs). Doing this, and jumping across the starter lugs the engine cranks over, but I can't seem to get it to catch. I drained the fuel filter to make sure no water, then bleed that, and also bleed the injector lines. It has been cold, the tractor has been outside and I think that is part of the dificulty getting it going.
As far as the wiring/electrical, the ignition switch is not springing back to ON from the START position, as previously mentioned, so I'm returning it. I'm going to pull the dash panel and trace every single wire, as using the key still won't start the machine. Also, I got the glow plug indicator to come on using the key a few times while jump starting, then it stopped working, and with out adequate glow plug use, and 15F temps w/out wind chill, I think I was fighting a losing battle trying to jump start it.
It took 4 of us, but we were able to roll it into the garage, bucket dragging the whole way. I'm looking to get a magnetic heater for it, so when I'm ready to start, I at least have something a little warmer to work with.
/ Ford 1900 wont start...electrical? #26
Eric,
I'm glad the starter is operational now. It appears to be an uphill battle all the way. When you bled the injector line all the way to the injector where you able to see live fuel delivery while cranking? I take it that you loosened the nut at the injector some to see mixture of air bubble and fuel till fuel became steady. A bit of air in the injector line and pump can pulsate without actually making flow as the air is a lot more compressible than diesel fuel. You can directly put electrical juice off the battery to the glow plug directly for 15-20 second before attempting to crank. I'll do that to see if I can the tractor to run and then keep it running for a while to burn off the crud and some good circulation in fuel to injector pump to injectors.
JC,
Thanks JC. It surely is an uphill battle, but I'm confident that man will beat machine in the end. Luckily I had an extra set of hands when bleeding the fuel system, and we did crack the nut at the injector until we observed steady flow of bubble free fuel. I like the idea of putting juice directly to the glow plugs, too. My goal at this point is to get it running so, as you say, fuel can circulate, the engine can heat up, and it can "clean" itself up. I think time and the elements have done a job on the wiring harness and connections, so I really need to thoroughly go through all of it now, rather than have to chase down another bad connection later on...
/ Ford 1900 wont start...electrical? #28
I'd fire it up like I suggested just to see if a lot of extra work in warranted or not. I know you spent money on the starter which you could not avoid. I believe steady and slow and , methodical and you'll beat the beast or put it to it's final resting place.
JC,
/ Ford 1900 wont start...electrical? #29
If it is 15 deg out side I have to have to heat the glowplugs for about 45 sec. Are you seeing any smoke from the stack while you are cranking it..
Bill
Hi all, I'm back with an update. I've been tinkering for the last couple of weeks. Checked all wires and connections, and pulled some unused wires for things like cigarette lighter, flashers, etc. (i'll be wiring new lights in later on). I tested the old ignition switch, and it appears to be working as it should. Now using the ignition switch and jumping the starter produces the same result, which is, the engine starts to crank, and continues to crank and crank, even when i let go of the key and it turns back to on. My first question is, why would jumping the starter, or turning the key to START make the engine start cranking and continue cranking...and the only way I can get it to stop is by pulling the negative battery lead. It seems there is still an electrical issue...thoughts?
That aside, with all the cranking, the engine never starts. The battery died from turning it over for so long. The glow plugs all work, the engine is puffing smoke out the exhaust stack, I even gave it a shot of ether right into the intake, and it just doesn't want to go. I installed an inline heater in the lower radiator hose, but from what I've read in other threads on here, I need to get the motor running so the coolant circulates and air is bleed out before I should use the heater. Is that true?
/ Ford 1900 wont start...electrical? #31
Okay, what you exactly mean by jumping and using the ignition switch. if you directly jumping the starter then you are bypassing all switches and safety so it will keep on cranking till you take the jumper off. If you continue doing this you'll toast your starter and that would be another overhaul of newly overhauled starter. Ether is not a recommended method that might lead to reversible damage to piston and rods. We know that your rig can crank so reason for not starting might be fuel or compression. if you see smoke than that might be enough reason for fuel entry i to combustion chamber. If fuel is not atomized you'll have difficulty getting it to go. If you can not maintain good compression then you can develop enough heat to ignite the diesel fuel. I'd first make sure I have good fuel to the injector. Might pull and injector out and verify the spray pattern against a card board. High pressure fuel can penetrate flesh pretty easily so yo need to be vary careful. You might also do a compression test thru the glow plug but need to have proper tools and adapters to do it. Might be able to rent compression tester for free from automotive shop.
verify fuel delivery system and report back and we'll see where we can go from there.
JC,
Once back together, I used the old ignition switch to try to start tractor from seat. I returned the new switch i ordered because it was defective (was sticking in start position) so i'm trying old one again, as I'm not sure it was the problem. So, I sat in the seat, held glow plugs for a bit, then tunred to START, and it just kept cranking when I let go. The only way I could get it to stop was by pulling the - battery cable. After this happened, i tried jumping across the starter terminals to get it to start, as I had done before, and even doing this the engine continued to turn over once I removed my jumper, so I had to pull the - battery cable again to get it to stop . I'm assuming something in the solenoid could be stuck, even though it's new?
I will check the fuel spray pattern from the injectors.
I have also emailed the previous owner to see if he ever had such problems.
I'm scrambling now, as we have a good size snow storm on the way.
/ Ford 1900 wont start...electrical? #33
Strange indeed, so let me get it right. when you jump it directly from the battery the starter start and would not want to stop even if you take the jumper cable off?? only way I think that might happen is if the solenoid plunger can not return to it normal position either due to the crud build up or damaged return spring. I wonder if continued cranking fused the contacts together. if engine turns on with the starter gears engaged then the starter can get damaged as in reverse it could potentially generate electricity. The electrical feed back can cause unpredictable damage.
when the starter continues cranking and you end up removing the wire, then have you ever reconnected the wire to see if starter cranks right away?
JC,
JC, you are correct with what you described. It continued cranking even when I jumped directly from battery to starter. I think I may have caused some damage by letting it crank for too long and heat up. I'll need to charge the battery to try again, and if this continues, I guess I'll have to pull the starter assembly again.
JC,
/ Ford 1900 wont start...electrical? #35
Freebird,
few questions here ; please respond one by one so I can try to decipher.
1) did you keep the positive and negative cables in tact and in position during your test?
2) did you actually took a " emergency jumper cable" and tried to start by using battery off of the tractor or any other portable battery? or did you short out connections on the starter using a screwdriver or short piece of wire to crank the engine?
3) when you used the jumper cable and tractor continued to crank, then what happened when you took the jumper off, did it continue to crank?
4) did you finally have to take a battery cable off the battery to stop cranking?
JC,
1) Positive and negative cable were in tact throught the test (except when I had to pull neg. cable to get starter to stop cranking)
2)After the continuos cranking using the key switch, I pulled the neg. battery cable to stop it. The i used a screwdriver to jump from pos. terminal on the starter to small solenoid terminal. This also resulted in the starter continually cranking, again. At this point the battery was weak, and it just about came to a stop, although it was still trying to start until I pulled the neg. battery cable again.
3)Yes, it continued to crank
4)Yup, had to pull neg. battery cable to stop the cranking.
I think those answers all sound like I've caused some damage to the starter or solenoid, or both.
Something I just thought of...because I was suspicious of the nuetral safety switch I have bypassed it for the purposes of getting the tractor started again. I used a length of new 12 gauge wire to connect the small terminal on the solenoid directly to the post on the ignition switch (I believe its the post #50). The original wiring for the nuetral switch had lighter gauge wire, maybe 14 or even 16 gauge. Could using this heavier gauge wire allow too much current to the solenoid? I wouldn't think so when considering it'sok to jump directly from the starter terminal to the solenoid terminal, but this was just a thought I had.
Freebird,
JC,
/ Ford 1900 wont start...electrical? #37
1-On the neutral safety " if it is open" clutch not pressed in, then it can keep the starter from cranking but having shorted out the neutral safety only allows it to start without "pressing the clutch" but in no way it will cause the starter to continue spinning.
2-when you used the screw driver to jump then, did you take it off to stop? if so, and it continued then there I think you fused the solenoid contacts due to heat , hence you needing to take the negative wire off.
My suggestion is to take the starter where yo had it repaired and just tell them " it continuous to spin after I turn it on". if they bench test it it should give them the same result. I think the motor is okay, it is the internal switch. They might be able to undue and clean the contacts or put a new switch in. Do you know all that they have done on their repair? do you have the parts that they replaced?
3- You still have fuel issue, don't continue cranking for a hope to get it started. investigate the fuel delivery.
4- I wish Bill would chime in , do you know if you have a seat switch or anything else beyond the neutral safety switch? do you know if you have solenoid for fuel shut off to your injector pump . I'll try to look at NH website to see that. My IT manual does not indicate any fuel shut off solenoid for 1700 or 1900.
JC,
I appreciate all of your help JC. I think the contacts are fused as you said, because when I removed the screwriver I was using to jump it, it did contiue to spin. I'm going to take your advice and bring it back to the shop that serviced it. The originally replaced the solenoid, replaced brushes, and cleaned armature. It a reputable Auto Electric shop, so I have faith in their quality of work.
I'm going to replace the fuel filter, and bleed the filter canister and pump again. I guess it's possible there was still some stubborn air in there while I was trying to start it. I'm not sure if there is a fuel shut of solenoid either.
I don't believe there are any other safety switches, aside from the one I bypassed.
Eric
JC,
/ Ford 1900 wont start...electrical? #39
I did recheck and you do not have fuel solenoid kill switch. 1700/1900 do not have any operator Operator Presence Safeties other than clutch Neutral safety. It is difficult to remove the air from fuel system without cranking. Potentially you can turn the crank pulley by a breaker bar and that's actually how they check the fuel injector pump timing. It is a more difficult thing to figure out if your fuel timing is off leading to hard start. You do not want to dork with it unless you see the nuts on the injector pump are lose or injector pump body has moved. If the engine ran prior to you buying ( if you can trust the seller) then I would not worry about it for now. Check you air filter (in your case it might be the same as mine, Oil bath). A plugged you oil bath type filter can severely effect engine start.
JC,
Eric
I think the pump is ok. It did run for me a few times, and it ran well. The previous owner said it always ran well for him. This is my first diesel, so it seems I may have underestimated just how important it is to have every last bit of air out of the system, assuming thats what's preventing me from getting it started. If I have to take the starter back to the shop, I'll try turning over with a breaker bar to see if I can bleed. If that doesn't work, I'll wait until U get the starter back, and I'll try cranking at short intervals to bleed air out.
Mistakes are a good way to learn (though expensive sometimes). I can gaurantee that I won't abuse the starter by letting it crank endlessly again.
When attempting to start, should the throttle lever be wide open? I don't have it wide open last night when I tried, but I'm thinking I may have the previous time I started it.
JC,
