Ford 1710 Timing
   / Ford 1710 Timing #1
sjab55
Dayton, OH
Ford 1710
I have a 1710 that is running rough and I suspect it is a timing problem. I have not been able to identify the number one cylinder. Can anyone help, front or back? Thanks
   / Ford 1710 Timing #2
If you can't find the #1 cylinder, how do you expect to check or improve the timing without a service manual? If you do have a service manual, I'm pretty certain it will tell you all you need to know about fuel injection timing and valve timing. For what it's worth, #1 is closest to the radiator and furthest from the clutch.
   / Ford 1710 Timing
Thanks Rick - I've read the service manual I have cover to cover and it doesn't define No. 1 cylinder which is what led me to post the question. If I were a true idiot I would have moved forward with a guess as to which was No.1
2018 WACKER NEUSON CORPORATION DBA WACKER NEUSON LTV6 LIGHT TOWER (A52472)
2018 WACKER NEUSON...
DOOSAN G25 GENERATOR (A52472)
DOOSAN G25...
2019 ExMark S-Series 72in Zero Turn Mower (A51692)
2019 ExMark...
TRUCKING INFO (A50775)
2011 TROXELL 130BBL (A52472)
2011 TROXELL...
Electric Forklift Pallet (A50322)
Electric Forklift...
