Ford 1710 (and others) Hydraulic Power Beyond Adapter Plate
   / Ford 1710 (and others) Hydraulic Power Beyond Adapter Plate #41
You can tie in as many open center valves as you want, provided they are all in series. So the oil flows out of the adapter block and must flow back into it in one circuit.
I need to machine some more of them so it may be a few weeks, but I'll let you know.
Are you still selling remote kits for the 1710 ford here is my email freedomautorepair2020@gmail.com thank you
   / Ford 1710 (and others) Hydraulic Power Beyond Adapter Plate #42
Hi Nick, That looks like a 1700 with draft control. It should have 2 levers for the three point. I have machined an adapter for a 1910 with draft control (see picture) which looks like the same shape and bolt pattern as your 1700. The only issue is that the 1910 has the relief valve upstream from that 4 bolt cover, where the 1700 has the relief built into that cover. I should be able to modify my adapter for the draft control 1910 to incorporate use of the relief valve.View attachment 745328View attachment 745329
Hi Ted
Did you ever manage to know if your adapter would work with the 4 bolt plate? I'm in New Zealand and I have a 1900 and it too has the 4 bolt plate and the draft lever too.
I really would like to use a 3 point hitch forklift attachment that needs an auxiliary hydraulic feed. Any help would be gratefully received.
Thanks
Jonathan
   / Ford 1710 (and others) Hydraulic Power Beyond Adapter Plate #43
Hello I'm new to this forum. I have Ford 1910 are you still making the power beyond blocks? I'm trying to hook up a backhoe.
   / Ford 1710 (and others) Hydraulic Power Beyond Adapter Plate #44
I'll be machining a batch of 10 so will have more available in a few weeks.
Hi Ted,
Beautiful work developing the Rear Remote for the Ford 1710. My Ford would love to be modified with your design. Do you sell the mounting plate and the plate for attaching the valves. Or even selling the cad files so I could get them machined?
Thanks for your time, Alie
Deere 331G (A50123)
Deere 331G (A50123)
2010 Lincoln MKS (A50324)
2010 Lincoln MKS...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
1995 Rinker Captiva 190 (A53473)
1995 Rinker...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53473)
NEW HOLLAND 706 30...
FORD 555B BACKHOE (A51246)
FORD 555B BACKHOE...
