Ford 1710 (and others) Hydraulic Power Beyond Adapter Plate
   / Ford 1710 (and others) Hydraulic Power Beyond Adapter Plate #31
Great then I would bolt that in between the two blocks , that would allow me to tie in the front loader . Does the block allow for additional implements to be tied in as well?
How do I go about getting the block?
Thanks
   / Ford 1710 (and others) Hydraulic Power Beyond Adapter Plate #32
Interesting...that makes sense, I've just never seen it before. The power beyond block I make for the draft control models should fit between the priority valve and relief valve.
Thanks
You can tie in as many open center valves as you want, provided they are all in series. So the oil flows out of the adapter block and must flow back into it in one circuit.
I need to machine some more of them so it may be a few weeks, but I'll let you know.
   / Ford 1710 (and others) Hydraulic Power Beyond Adapter Plate #34
Much appreciated. Looking
Forward to getting the front loader mounted, up and running!
   / Ford 1710 (and others) Hydraulic Power Beyond Adapter Plate #35
Will your adapter work to add more values to a TC tractor that has one factory valve?
I make a rear remote kit for the 20 series tractors, and the TC45 looks similar. But you can still get the full kit from NH for adding a second valve to your tractor. PN 84171957.
   / Ford 1710 (and others) Hydraulic Power Beyond Adapter Plate #37
$150 shipped. It includes all the fittings, orings, and hardware to mount. I made up 3 of them so have 2 left on the shelf. Send me a PM if you're interested.
Do you still have these for sale in need of one for my 1900
   / Ford 1710 (and others) Hydraulic Power Beyond Adapter Plate #38
Just completed my order of a dual rear-remote setup for my Ford 1910. Ted was super helpful and gladly answered all of my newbie questions. Looking forward to installation and use!!
   / Ford 1710 (and others) Hydraulic Power Beyond Adapter Plate #39
A few pics of my new RearRemote setup from Ted, who was awesome and speedy to work with. I don't yet have a top/tilt kit, but I'm working on it.
Here's what I ordered and installed:
Small cap is removed from under seat location to reveal pre-plumbed hydraulics location. The o-rings were supplied in Teds kit and fit nicely.
Next to be added was the mounting plate which the valves will in turn mount to. All hardware and o-rings are supplied in the kit, which was shipped speedily and well boxed.
Each valve unit is an individual part of the sandwich, with a cover plate on the end. I pre-assembled the sandwich before attaching the whole thing to the mounting plate. Not shown are o-rings between each plate, again supplied with the kit.
Final view after adding the supplied levers. Note that one lever is ever-so-slightly more bent than the other - this allows your seat to be fully raised without impacting the levers. A nice touch and a great product. Thanks Ted!
   / Ford 1710 (and others) Hydraulic Power Beyond Adapter Plate #40
Ryobi Sliding Miter Saw (A51573)
Ryobi Sliding...
2018 AMERICAN HAULER (A52576)
2018 AMERICAN...
2007 Ingersoll Rand P185WJD Towable Diesel Air Compressor (A52377)
2007 Ingersoll...
2005 Superior Trailers VT130 T/A Vacuum Trailer (A51692)
2005 Superior...
2025 New/Unused Wolverine Hydraulic Skid Steer Pallet Forks (A51573)
2025 New/Unused...
Approximately 250 Traffic Cones (A51573)
Approximately 250...
