Ford 1700 - Voltage Regulator replacement
   / Ford 1700 - Voltage Regulator replacement #11
Yes, solid state regulator. Alternator is:
WPS
Model: 1-1111-01HI-2/1405
Serial: 218L1
12 volt
35 amp
   / Ford 1700 - Voltage Regulator replacement #12
I think your Datsun external 35a and 50a alt ( pulleys) will work. Early internal regulated versions are similar to a Delco 10si if you are willing to, get a proper plug and by pass the regulator and monkey with the wiring.
DS
   / Ford 1700 - Voltage Regulator replacement #13
If anyone is still out there looking for information on this, the voltage regulator for a 1972 Nissan/Datson 680 truck work. Denso PN TG026000-7200 and the Hitachi TL1Z-61D make sure it has the HBA12-2 connector. For the alternator I used a ACDelco 334-1547
Search; FD elecman HBA12-2
   / Ford 1700 - Voltage Regulator replacement #14
When I replaced miy 1700 alternator, it was the same as a 1974 Nissan 260Z. Old post, but my help someone.
   / Ford 1700 - Voltage Regulator replacement #15
The Bosch number is AL231X I believe it fits 1500, 1700, 1900, 1910 and 2010. But double check to be safe.
   / Ford 1700 - Voltage Regulator replacement #16
Thanks for the info... I was given the 1700 2 years ago; my first tractor. Its been a learning experience and fun!. I now have a spread sheet on alternate parts and where I got them from to save money. Most brands of Alternators that I looked at are rebuilt Hitachi's including the ACDelco I mentioned earlier.
   / Ford 1700 - Voltage Regulator replacement #17
Old post I know, but I too have a 1700 with is having a voltage regulation issue. I picked up a new battery for it a few weeks ago and after bush hogging for a couple of hours I shut it down and noticed this hissing sound from the battery. Let it sit overnight and then started it back up this morning. At 1200 rpm, I was reading 18.4 volts across the battery terminals! I hope I didn't kill the battery (Die Hard Silver that was pretty expensive).
I have the original Hitachi alternator and I'm sure the original voltage regular as well.
This guy should fit the bill, right? (I would have to switch the connector over from the old one)
https://www.ebay.com/i/164095380450...wK3jtKPnrUjiQW8rz1p4VKalwVnEgWAkaAng5EALw_wcB
Or maybe this one would be a better choice?
JDM AC 12V REGULATOR VOLTAGE Fit DATSUN FAIRLADY BLUEBIRD Pickup Truck 1966-198 | eBay
Thanks!
   / Ford 1700 - Voltage Regulator replacement #18
The second one looks more like what you need. The regulator I am currently using is a TL1Z-61D, I believe it is made by Hitachi. They need to be the HBA12-2 connector type.
   / Ford 1700 - Voltage Regulator replacement #19
I went and looked at the JDM link and the pictures showed a label "AVR-811". I looked up that number on the Newera website and that looks correct. (See Image)
   / Ford 1700 - Voltage Regulator replacement #20
I ended up getting this one:
Made to Fit Ford Tractor Regulator SBA185516:( 1 131 15 151 16 17 17 6117 | eBay
It is solid state. However, it did not work. As soon as I started up, the charge light lit up and sure enough, I'm only getting 12.6 volts across the battery. So that was a waste of $40. They say returns not accepted if used, so since I did use it for all of 45 seconds, I guess it is now mine. :(
I took a look at the old one, and it seems to be ok. The small resistor is measuring 32 ohms, and the large one is measuring 42 ohms to the middle tap and 0.4 ohms from the middle tap to the other end. I guess I'll try to clean the relay contacts to see if that will help?
2015 KUBOTA 1140CRX RTV (A51406)
2015 KUBOTA...
2008 John Deere 608C combine head (A50657)
2008 John Deere...
2023 John Deere RD40F Draper Head (A53342)
2023 John Deere...
1267 (A50490)
1267 (A50490)
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A52377)
2015 Chevrolet...
(4) STEEL CARTS W/ WHEELS (A51248)
(4) STEEL CARTS W/...
