Ford 1700 muffler
   / Ford 1700 muffler #1
JLWjr
Ford 1700
Anyone have a reliable source for an aftermarket muffler for a Ford 1700(North American). OEM ones are over $300.00
   / Ford 1700 muffler #3
If it isn't cut off the flange and weld the old flange to it if it hasn't rusted away
   / Ford 1700 muffler #5
Allstates tractor parts.
   / Ford 1700 muffler
Many thanks for the info.
   / Ford 1700 muffler #7
Ford 1100 fwd tractor with a bad muffler a few years back, and a new one was $500. I sold the tractor to a friend of mine, and he ripped the muffler off on a tree. So...I went to a tractor salvage place (not many around here) and purchased another muffler similar in size. I built a small adapter plate for him to mount it to the exhaust manifold. I will get to see if it is still working right soon, because I am going to go after that tractor in a couple of weeks and try to get it running again. He is bad about not using it often enough and it eventually quits starting.
David from jax
   / Ford 1700 muffler #8
I had to do this on my 1900 Ford. The base is not the same and most similar mufflers were too large of a diameter. No replacement will look the same as the Ford muffler but maybe you can find a similar foreign donor portion from a junkyard. If you have to, get a simple plate machined with a hole to fit the muffler pipe.
   / Ford 1700 muffler #9
Be careful, I bought an aftermarket one on line years ago, and the flange bolt pattern was wrong. I ended up slotting the holes to fit the bigger pattern on the 1700 head. On the 1600, I just cut off the pipe just below the muffler and picked up a TSC muffler and rain cap. Put a U-clamp on it, and never had an issue. The OEM flanges and pipe is heavy duty, so it will last a lot longer than the mufflers.
2023 John Deere RD40F Draper Head (A53342)
2023 John Deere...
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
Pallet of (8) 8 Lug Misc Wheels (A51573)
Pallet of (8) 8...
Electric Concrete Mixer (A51573)
Electric Concrete...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
