Ford 1700 muffler
/ Ford 1700 muffler #1
JLWjr
Member
Ford 1700
Anyone have a reliable source for an aftermarket muffler for a Ford 1700(North American). OEM ones are over $300.00
/ Ford 1700 muffler #3
If it isn't cut off the flange and weld the old flange to it if it hasn't rusted away
/ Ford 1700 muffler
Many thanks for the info.
/ Ford 1700 muffler #7
Ford 1100 fwd tractor with a bad muffler a few years back, and a new one was $500. I sold the tractor to a friend of mine, and he ripped the muffler off on a tree. So...I went to a tractor salvage place (not many around here) and purchased another muffler similar in size. I built a small adapter plate for him to mount it to the exhaust manifold. I will get to see if it is still working right soon, because I am going to go after that tractor in a couple of weeks and try to get it running again. He is bad about not using it often enough and it eventually quits starting.
David from jax
/ Ford 1700 muffler #8
I had to do this on my 1900 Ford. The base is not the same and most similar mufflers were too large of a diameter. No replacement will look the same as the Ford muffler but maybe you can find a similar foreign donor portion from a junkyard. If you have to, get a simple plate machined with a hole to fit the muffler pipe.
/ Ford 1700 muffler #9
Be careful, I bought an aftermarket one on line years ago, and the flange bolt pattern was wrong. I ended up slotting the holes to fit the bigger pattern on the 1700 head. On the 1600, I just cut off the pipe just below the muffler and picked up a TSC muffler and rain cap. Put a U-clamp on it, and never had an issue. The OEM flanges and pipe is heavy duty, so it will last a lot longer than the mufflers.
TWO PALLETS OF HYD TANK, V8 ENGINE BLOCK/PARTS (A68842)
TWO PALLETS OF HYD...
2018 CATERPILLAR 573D FELLER BUNCHER (A65053)
2018 CATERPILLAR...
GAS CYLINDER TRANSPORT BED (A67714)
GAS CYLINDER...
55 GALLON CONTAINERS OF FLUIDS QTY OF 6 (A67714)
55 GALLON...
2020 Cat 302.7D Mini Excavator (A64047)
2020 Cat 302.7D...
2016 Chevrolet Tahoe SUV (A66738)
2016 Chevrolet...
