Ford 1700 - 770 loader - float position
   / Ford 1700 - 770 loader - float position #1
nsmithnd
Bismarck, ND
Ford 1700
Curious how the float position is expected to act on a 770 loader.
I've noticed when using the loader that raising and lowering it is a bit scary because the float position can easily be reached and causes the bucket to jump or drop quickly if I'm not careful.
Should the float position be easy to get to or should it take some force? I've got an old Bolens garden tractor and I have to hit the lever pretty hard to "pop" it into the float position.
   / Ford 1700 - 770 loader - float position #2
Is there a float position on the two lever control?
   / Ford 1700 - 770 loader - float position #3
The float position on many spools have a detent in the spools where the little steel balls drop into and lock.
Perhaps there is crud and rust buildup on the detent ..
You might be able to rotate the spool 180 for another part of the detent.
Remove the can on the bottom and inspect and clean and replace anything necessary.
   / Ford 1700 - 770 loader - float position #4
Please pardon me for going off track a bit. Would someone please explain what "float position" means; what it does? Thank you.
   / Ford 1700 - 770 loader - float position #5
Float position is a detented position used for grading , back blading, otherwise the bucket follows the conture of the ground.
All ports on that spool are open to tank.
Not all tractors have it .
If you should go to float inadvertently, it could cause problems.
   / Ford 1700 - 770 loader - float position #6
The reason I ask is that I have a 770 loader (no A or B suffix) and the manual does not mention a float position on the controls.
I went out and checked it again. Can barely feel the detent position, but it is definitely there. Guess I've always worn gloves when using the loader so might explain why I haven't "felt" it while using it.
Thanks for the info J_J, I'll pull the cap and check things out (and spin the spool if needed).
mostly_gas, the diagram in the first post is the control valve I have. The left (boom) lever has a longer cap on it than the bucket lever. It also has more forward lever movement than the right. If both sides have a short cap on them, then probably no float position(?).
Thanks
-Neil
   / Ford 1700 - 770 loader - float position #8
I just bought a Ford 1910 with the 770 loader on it. I know it has the float position because the previous owner showed me and I used it for the first week.
Problem is, now the float position doesn't work anymore. I noticed that when I parked the tractor last, that I left the loader in float position. Was that a bad thing to do?
What kind of troubleshooting do I need to go through to figure out the problem. All other functionality of the loader works fine (as far as I can tell).
Caveat: I'm new to loaders, so my previous statement may not mean much.
thanks for the help
Chris
   / Ford 1700 - 770 loader - float position #9
Chris,
I am by no means an expert. I will look at the owner's manual for the loader and let you know tomorrow what it says.
Searching for loader float position on TBN or elsewhere might give you some ideas. I'll do that, too.
I'd make sure the hydraulic fluid is full. And maybe GENTLY tap on the loader control housing while operating the loader controls.
I have no idea if it is bad to leave the control in the float position. I'll get back to you tomorrow with whatever I find.
Bob
   / Ford 1700 - 770 loader - float position #10
I just bought a Ford 1910 with the 770 loader on it. I know it has the float position because the previous owner showed me and I used it for the first week. Problem is, now the float position doesn't work anymore. I noticed that when I parked the tractor last, that I left the loader in float position. Was that a bad thing to do? What kind of troubleshooting do I need to go through to figure out the problem. All other functionality of the loader works fine (as far as I can tell). Caveat: I'm new to loaders, so my previous statement may not mean much. thanks for the help Chris
Are you sure you pushed the lever past the detent. On my 1700 it was very hard to get past it and back. It should not hurt it to leave it in float.
2005 Toyota Highlander SUV (A56859)
2005 Toyota...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A57880)
2017 FREIGHTLINER...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2017 Ford Fusion Hybrid Sedan (A56859)
2017 Ford Fusion...
2017 Ditch Witch FX50 (A55973)
2017 Ditch Witch...
2017 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A55973)
2017 Chevrolet...
