Loader Ford 1700 4WD Injector pump timing?
   / Ford 1700 4WD Injector pump timing? #1
TJones8357
Ford1700 4WD
I had to remove my injector pump to send away to rebuild. While the pump was away the tractor was moved and the engine was turned over. I re-installed the pump but now the engine will not start. Does anybody have the procedure for timing this engine? Adding to my confusion is the manuel says the firing order is 2-1. Could I have the pump 180 degress out?
:confused3:
   / Ford 1700 4WD Injector pump timing? #2
:confused3:
Please refer to attached procedure.
   / Ford 1700 4WD Injector pump timing? #4
:thumbsup: good luck. when yu get it all together then put a witness mark between back of the timing gear cover and the body of injector pump.
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
INOP/NON-RUNNING 2006 Mack CV713 Granite Truck, VIN # 1M2AG11C56M039887 (A51572)
INOP/NON-RUNNING...
2015 MAC FLATBED 48FT TRAILER (A52141)
2015 MAC FLATBED...
WESSEX CHT-100R-E LOT NUMBER 237 (A53084)
WESSEX CHT-100R-E...
2025 New/Unused Wolverine 32in Hydraulic Backhoe Excavator (A51573)
2025 New/Unused...
