Loader Ford 1700 4WD Injector pump timing?
   / Ford 1700 4WD Injector pump timing? #1
TJones8357
Ford1700 4WD
I had to remove my injector pump to send away to rebuild. While the pump was away the tractor was moved and the engine was turned over. I re-installed the pump but now the engine will not start. Does anybody have the procedure for timing this engine? Adding to my confusion is the manuel says the firing order is 2-1. Could I have the pump 180 degress out?
:confused3:
   / Ford 1700 4WD Injector pump timing? #2
:confused3:
Please refer to attached procedure.
   / Ford 1700 4WD Injector pump timing? #4
:thumbsup: good luck. when yu get it all together then put a witness mark between back of the timing gear cover and the body of injector pump.
2011 Chevrolet Impala Sedan (A51694)
2011 Chevrolet...
New/Unused Mower King 48in Quick Attach Trencher (A51573)
New/Unused Mower...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
COOPER LIGHTING CAT. NO. MHEP-22/28-175-MT (A53472)
COOPER LIGHTING...
Mini Skid Steer Sweeper Attachment (A51573)
Mini Skid Steer...
2018 RoGator 1100C (A53472)
2018 RoGator 1100C...
