Loader Ford 1700 4WD Injector pump timing?
   / Ford 1700 4WD Injector pump timing? #1
TJones8357
Ford1700 4WD
I had to remove my injector pump to send away to rebuild. While the pump was away the tractor was moved and the engine was turned over. I re-installed the pump but now the engine will not start. Does anybody have the procedure for timing this engine? Adding to my confusion is the manuel says the firing order is 2-1. Could I have the pump 180 degress out?
:confused3:
   / Ford 1700 4WD Injector pump timing? #2
:confused3:
Please refer to attached procedure.
   / Ford 1700 4WD Injector pump timing? #4
:thumbsup: good luck. when yu get it all together then put a witness mark between back of the timing gear cover and the body of injector pump.
2018 NISSAN TITAN PICKUP TRUCK (A51222)
2018 NISSAN TITAN...
19011 (A48082)
19011 (A48082)
John Deere X740 Mower (A50514)
John Deere X740...
2024 AGT INDUSTRIAL QHT-500FL CONCRETE BUGGY (A51243)
2024 AGT...
2022 CATERPILLAR 306CR EXCAVATOR (A51242)
2022 CATERPILLAR...
2019 CATERPILLAR 299D2 XHP SKID STEER (A51242)
2019 CATERPILLAR...
