Loader Ford 1700 4WD Injector pump timing?
   / Ford 1700 4WD Injector pump timing? #1
TJones8357
Ford1700 4WD
I had to remove my injector pump to send away to rebuild. While the pump was away the tractor was moved and the engine was turned over. I re-installed the pump but now the engine will not start. Does anybody have the procedure for timing this engine? Adding to my confusion is the manuel says the firing order is 2-1. Could I have the pump 180 degress out?
:confused3:
   / Ford 1700 4WD Injector pump timing? #2
:confused3:
Please refer to attached procedure.
   / Ford 1700 4WD Injector pump timing? #4
:thumbsup: good luck. when yu get it all together then put a witness mark between back of the timing gear cover and the body of injector pump.
2006 ISUZU NPR (A50323)
2006 ISUZU NPR...
UNUSED CFG Industrial MX15RX Mini Excavator (A47384)
UNUSED CFG...
2018 TAKEUCHI TB240 EXCAVATOR (A51242)
2018 TAKEUCHI...
2013 HINO 388 (A50854)
2006 International 4400 LP Ambulance (A50323)
2006 International...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
