Ford 1600 Strter issue
/ Ford 1600 Strter issue #1
BEN1957
Huntsville, Alabama
Ford 1600
I have a Ford 1600 where I recently replaced the switch and the starter Solenoid assy. When I turn the key on the switch the starter turns over as it should. If I turn the switch to off the starter keeps turning. From everything I can tell the switch is fine and is wired correctly. I can disconnect the starter wire from the Solenoid and turn the key and I get 12V. when I turn the key to off the voltage drops. This tells me the switch is ok. Could it be a starter or Solenoid issue.
/ Ford 1600 Strter issue #2
It sounds like the solenoid is sticking.
Bill
I just tried a brand new Solenoid and it did exactly the same. Turn the switch and the engine turns over but turn off the switch and it keeps trying to turn over until I disc0nnect the battery.I am thinking it may be the starter but I don't know why. I can disconnet the switch from the solenoid and short the terminals on the solenoid and the starter turns over. When I remove the screw driver it still turns over until I disconnect the battery.
/ Ford 1600 Strter issue #5
The switch should cut power to the starter in the off position.
I do not even have the starter connected to the solenoid and the starter still runs all the time once engaged.
/ Ford 1600 Strter issue #7
how is power getting to the starter?
I don't have a tractor like yours, but I can try to help.
EDIT: I pm'ed Soundguy. He's great with Ford's.
/ Ford 1600 Strter issue #8
is it stuck engaged to the ring gear?
The only wires currently attached to the solenoid is the hot wire directly from the battery and the wire directly to the starter. I removed the starter from the fly wheel housing and shorted the terminals on the solenoid. The starter engages but stays engaged even when the terminals are no longer shorted.
/ Ford 1600 Strter issue #10
For some reason the solenoid is sticking. Are you sure you have the right solenoid.
Bill
/ Ford 1600 Strter issue #11
When you "short" the terminals, which terminals are you referring to? The two large terminals(battery positive and the lead to the brushes, or battery positive and the switch terminal) Are you sure you have the correct solenoid(s) for this starter? It's possible for contacts to stick, but uncommon for new solenoids, even more so for two of them. When you short the terminals and the starter spins have you tried to check the switch terminal on the solenoid to see if 12v is present there even when no wires are connected? That would indicate the coil may be supplied with voltage from the contacts once they engage. I know that doesn't really make sense, but it brings me back to the question about correct solenoids. Also, what was the original problem you solved by replacing the solenoid to begin with?
I am not positive the solenoid is correct. I will try to check that. I ordered them online based on my model and it does mount properly to the starter.
/ Ford 1600 Strter issue #13
without battery supplied.. does it stay kicked out?
