Ford 1510 Differential Lock
/ Ford 1510 Differential Lock #1
mongobird
Ford 1510
My Ford 1510 Differential Lock does not lock anymore. I assume I will need to open the top of the transmission. Can anyone shed light on this? It sure would be nice if I could fix it over the summer so I could have it for snowplowing next year.
/ Ford 1510 Differential Lock #2
Here is a link to Ford/NewHolland parts, I selected the differential lock page: Differential & Differential Lock Linkage, 1310, 1510, 1710 | New Holland Agriculture | MyCNH US Store
Looks like there is a bit more to it than on my Case backhoe which you can get to from the outside. If you don't have a service manual, I'd be getting one, might make the job a little easier.
In the future if you need to lock the differential, stop, engage it then take off again, it will engage when wheels slip. Engaging it when under a load and wheel is spinning puts a lot of torque on those little pins that lock it up. It may take it for a while but will eventually shear those pins off.
Until then you can feather one brake on the wheel that is spinning, and it will power out to the other wheel.
/ Ford 1510 Differential Lock #3
Are you sure the mechanism is working? It might be frozen in the unlocked position.
I agree with DJ.
New/Unused AGT Quick Attach Auger with Three Bits (A61166)
New/Unused AGT...
(INOP) 2003 KYMCO MX 150 ATV (A62130)
(INOP) 2003 KYMCO...
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A61166)
New/Unused...
2019 KUBOTA SVL95-2S SKID STEER (A62129)
2019 KUBOTA...
2017 Ford F-250 Pickup Truck (A61568)
2017 Ford F-250...
207270 (A52708)
207270 (A52708)
