ford 1300 clutch
   / ford 1300 clutch #1
dansford1300
ford 1300
I am having a problem with my clutch it won't allow it to go in gear need input on what type it is dry or wet thanx
   / ford 1300 clutch #3
Hello & WELCOME to TBN!
I moved your thread to the Ford Vintage Tractors Forum. :)
   / ford 1300 clutch #5
sounds ;ike it's a classic stuck / rusted clutch.
block the pedal for a couple days. might get lucky.. it might just pop free.
if not, put it in gear with the clutch blocked, and bump the starter over repeatedly.. just lil bumps.. that usually pops em loose if they can be popped loose.
post back
soundguy
   / ford 1300 clutch
Thanks illl try that after elk hunt
   / ford 1300 clutch #7
if yer around it, just toss a block onto the clutch pedal to let it hold it down a few days till you can start waving wrenches over it and do the real work.
might get lucky!
soundguy
   / ford 1300 clutch
Blocked it and it worked thanks :)
   / ford 1300 clutch #9
now remember to block it when you won't be using it regularly.
some new tractors actually come with a wood block to do that with..
good luck
soundguy
   / ford 1300 clutch
ThankS again I will keep that in mind. The tractor has only 260hrs and has sat for some time .its nice to have tractorsbynet to find ansewers to questions thanks. Again
2025 New/Unused Wolverine 72'' Skid Steer Ripper (A51573)
2025 New/Unused...
New Holland B95 Backhoe (A50490)
New Holland B95...
CONTACT INFO LOT NUMBER 6 (A53084)
CONTACT INFO LOT...
New/Unused 48in Quick Attach Pallet Forks (A51573)
New/Unused 48in...
New Long Forks (A53002)
New Long Forks...
