FORCING GREASE IN A ZERK?
/ FORCING GREASE IN A ZERK? #1
fried1765
Super Star Member
Kubota L48 TLB, Ford 1920 FEL, 8N Ford, Gravely 12 HP "Professional", 48" SCAG Liberty
I have a, new to me, 2011 Nissan forklift that will not accept grease in one zerk.
I have removed the zerk, and attached it to my grease gun, and grease flows readily.
The zerk is located in the end of a pin, and fills the pin completely with grease.
The grease inside the pin is soft, and I have tried cleaning the pin center completely out.
Grease should come out at both ends of the pin, to lubricate the pin (a washer on each end), where it passes through each side of the pin mount, but none does. The pin is a pivot mount (very little movement) for a hydraulic cylinder that tilts the forks.
Any ideas on how to get grease to both ends of this pin?
/ FORCING GREASE IN A ZERK? #2
Remove the pin, clean the grease passages, flush with new grease and replace.
/ FORCING GREASE IN A ZERK? #3
ive used the heat wrench on my skid steer pins many times when they wouldn't take grease.
Very tough job to remove the pin, (nasty location) but I may have to do that.
Was hoping for an easier suggestion.
/ FORCING GREASE IN A ZERK? #5
sometimes I have to grease a few pins while bucket is fully raised instead of resting position, try greasing it in another position if u can. Ive never had to remove a pin for it to take grease....heating is my last resort but has worked every time
/ FORCING GREASE IN A ZERK? #6
I had a plugged zerk on my GN trailer jack and after fighting with it for a few years I finally tried a Loc-n-lub grease zerk connector. I could put much more pressure in the zerk with the same grease gun. Popped it right open.
/ FORCING GREASE IN A ZERK? #7
Somewhere in the dark past, seems there was a grease fitting that you could strike with a hammer, thus giving a high pressure momentary shock to clear plugged ports.
/ FORCING GREASE IN A ZERK? #8
I have one of those, they do work "some times"...
SR
/ FORCING GREASE IN A ZERK? #10
I wonder if the pin has a grease groove going around the circumference connecting the cross holes?
I have a Lock-N-Lube, but it is hundreds of miles way.
Guess I better bring it back.
I do want to try everything BEFORE taking the whole assembly apart.
I just ordered it on Amazon.
IPA Grease Joint Rejuvenator - patented - made in USA
$38.72 + tax.
A bit pricey for what it is, but I gotta try!
I do NOT want to take that pivot pin assembly apart!
I will plan to use Kroil as the light weight penetrating lubricant.
I love the stuff!
/ FORCING GREASE IN A ZERK? #13
When I bought my backhoe the loader apparently hadn’t be greased in years. It must not have had much use either because there wasn’t any wear to the pins and bushings. There was 2 pins that wouldn’t take grease. I tried soaking them in Kroil and heating them. One took grease and I had to take the other one apart and clean it. I didn’t have my cordless grease gun them but it claims 10,000 psi where most hand pump guns are rated about half that. Rather there’s any truth to that I don’t know.
/ FORCING GREASE IN A ZERK? #14
See if this works. Remove the zerk, and once again remove what grease you can get out. Put a small amount of grease on you finger, and make a dam with the grease where the zerk goes in. 1/2 to 2/3 as high as the hole is fine. Spray some penetrate in the hole, until it runs out, but not enough to wash out the dam. Replace the zerk, then try pumping grease in it. When you meet resistance, keep as much pressure on the handle as you can. Hopefully, you'll slowly feel the liquid penetrate forcing it's way out,, then give way with grease behind it.
Learned this trick from an old heavy truck mechanic, that used this to get grease in king pins, that were frozen up, from lack of grease. I've had about a 95% success rate doing this. Most hand guns develop 12,000 psi, that's a lot of pressure behind a liquid.
If that doesn't work, you can always go to plan B.
/ FORCING GREASE IN A ZERK? #15
I have one of those tools, and was not impressed with it when I put grease in it, but when I put diesel in it it worked great, the thinner fluid would penetrate the old hardened grease, and wash it out,
I is not 100% but I had a old JD drill that was 65 years old, and had some that would not take grease it with the diesel it opened up 95% of the plugged zerks, some I just had to take it apart and use a drill bit and drill out the grease and dirt that was hardened up in them it was like cement in them,
like said try a few different positions, (my disk one could not grease it unless it lowered all the way, on the lift,),the metal will wear and make a seal so tight of a seal, that it is like trying to grease a blind hole, the grease has to have some place to go,
Guess I could have tried that BEFORE ordering the IPA Grease Joint Rejuvenator from Amazon.
Think I'll give the tool a try now though, since it is on the way.
/ FORCING GREASE IN A ZERK? #17
I have ONE zerk on the grapple that I must raise the grapple so it will accept grease. In the down, resting position - no joy.
I have tried cycling the forklift cylinder joint, while at the same time attempting to force grease.
No joy!
/ FORCING GREASE IN A ZERK? #19
TSC has the rejuvenator tool on the rack of grease tools for about the same ridiculous price as Amazon. I find often that Amazon is more expensive than local cost for same tools, YMMV?
Good luck getting it opened up.
My only thought that hasn't been covered is: if you had your Loc-N-Lube fitting I would try to pressurize the grease to the zerk while using an impact gun to vibrate the pin and see if the combo would eventually force the grease through the 'cemented in' grease.
You could return the rejuvenator to Amazon and buy the Lok-n-lube fitting you may not already have: they now have a long nipple version that reaches where the original short nipple can't reach. Then you'd have both and could keep them in your different locations, and I think you'll find better chance of success with the L-N-Lube tool.:confused3:
/ FORCING GREASE IN A ZERK? #20
I've put WD40 in mine, and got it to work...
SR
2013 INTERNATIONAL DURASTAR 4400 FORESTRY BKT TRK (A63276)
2013 INTERNATIONAL...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2005 Stertil Koni ST-1082R 18000lbs 4-Post Auto Lift (A61572)
2005 Stertil Koni...
2006 Heil DOT 407 Aluminum Ethanol Tanker Trailer (A64194)
2006 Heil DOT 407...
Bobcat T62 Compact Track Loader Skid Steer (A64553)
Bobcat T62 Compact...
Ingersoll Rand DD-24 Tandem Smooth Drum Vibratory Roller (A64553)
Ingersoll Rand...
