For all the new MT125 owners out there
   / For all the new MT125 owners out there #41
Someone recommended using safety wire thru the roll pins so they couldn't back out. I would imagine a greased piece of mechanics wire would last for years.
I agree. I think if mine ever comes out again, I will put a little longer one and and use wire. So far, so good.
   / For all the new MT125 owners out there #42
Good deal. I think safety wiring things has become a lost art with the invention of nyloc nuts and loctight. Worked on KC130s and everything was safety wired.
   / For all the new MT125 owners out there #43
In my earlier year in the Army, I supervised an Armament shop. I have wire tied a few 50 Cals and other weapon systems. LOL. They gave us those cool wire tie pliers with cork screw handle. :thumbsup:
   / For all the new MT125 owners out there #44
Hahahaha Those safety wire pliers were great! I just wish I hadn't given all mine away. Wouldn't use them enough now to justify buying a new pair.
   / For all the new MT125 owners out there #45
Did anyone post a picture of the new drain plug? I am around 90 hours now and I had the 50 hour service done by the dealer and he replaced the drain plug. I noticed a wet spot under the front axle of my tractor recently and confirmed it is oil. The attached picture of the front axle shows the drips of oil coming down. I confirmed there was oil around the drain plug in the other picture. I wiped it clean and tried to confirm no oil was above that point, and am pretty sure that is the source. Oil reappeared near the drain plug when I checked 24 hours later. The oil on the dipstick is in the middle of the range.
The plug is an 8mm hex that I can't get good access to. The short side of my hex wrench is not long enough to reach it and I can't turn it with the long end in. I ordered a T handle 8mm hex wrench to see if I can get better leverage.
   / For all the new MT125 owners out there #46
That is the correct plug and I used an allen socket with a 3/8 drive ratchet as mine leaked right off. Not as bad as your for sure. I would just snug it up as that is all I did to mine and solved the problem. Hope this helps.
Lisa
Mine is the same type of plug also. I changed it out myself when I did the last oil change. I remember it had one of those copper washers on it. I also used an Allen point 3/8 drive, extention, and ratchet. Didn't torque it real tight, but pretty tight, if you know what I mean. No leaks observed so far, but I've only started up and moved in and out of the garage a couple times, no real work.
Oh, I can't remember if the copper washer was one of the type that has the rubber center ring / seal
   / For all the new MT125 owners out there #49
Thanks for the tip on the Allen sockets, I have added a set to my wish lists.
Hey mslisaj....check your PM box...
2007 Godwin Pumps GHP45KW-RC 45kW Towable Diesel Generator (A56857)
2007 Godwin Pumps...
2021 Caterpillar 299D3 High Flow Compact Track Loader Skid Steer (A55973)
2021 Caterpillar...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2007 MACK CTP713 TRI AXLE DUMP TRUCK (A58018)
2007 MACK CTP713...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
PALLETS OF HEAVYEQUIPMENT (A58214)
PALLETS OF...
