Food Plot Screen
/ Food Plot Screen #1
Smallplot
Pike County Illinois
1974 IH 1066, 1969 IH 756/FEL, and 2011 TYM T603 Cab/FEL
I am going to share some photos of my 2012 planting of a Egyptian Wheat food plot screen. The seeds are planted at 1 inch deep on 7.5 in row spacing at a rate of 4.5 pounds per acre.
Here is what I started with.
Next the area for the screen was mowed.
The next step was to till the area.
Next broadcast with a hand spreader lime, 12-12-12, and urea.
Amendments were tilled into the soil profile creating a great seedbed.
Now to ready the drill.
The drill was first calibrated with the Egyptian Wheat seeds. I found the transmission gear of 2 was best suited with my seed setting at 7 on my legume seed box.
And the finished result looks something like this
The only thing left is waiting for emergence and spraying with some Atrazine to control the weeds.
If you would like to see the drill in action check out my short video on youtube. [ame=http://www.youtube.com/watch?v=f85UknkcOm8&feature=g-upl]Planting Egyptian Wheat Screen 2012 - YouTube[/ame]
Tractor is a TYM T603
/ Food Plot Screen #2
That's a good job. Here are some pictures of Egyptian Wheat, BT Millett, and Iron Clay peas planted in the same row, using a set of old Covington planters and a Ford 600. Pics are from about 5 years back. I still have some E Wheat volunteer in that field. I couldn't use herbicide because of the different crops.
/ Food Plot Screen
That old covington planter did the job!
/ Food Plot Screen
5/23/12 Update
Checked the status of my EW screen today. An over all look showed nothing but upon closer examination I saw these. Very small green shoots reaching for the sky. The green shoots appear only in the tracks left by the press wheels and appear they are EW seedlings.
Just to make certain that what was growing is indeed EW dug up one of the seedlings and sure enough the seedlings are attached to the EW seed I planted.
The screen is certainly on it's way.
Dan
/ Food Plot Screen #5
Good to see you posting over here. I broadcasted my EW about ten days ago and had some good rains since....but have not been back to my land to see if I got some germination. Will get there in the next days. Hoping to see what you have shown here. Thanks.
I didn't fertilize before I planted.....may have to top dress it. I did get a good stand of EW in the past via my method.....so I'm hoping to do it again. It does make a great screen.....and the wildlife like the seeds.
/ Food Plot Screen
My brother checked our screen today and you can row it pretty well today. I will try to get some pictures tomorrow. Looks like plants are couple of inches tall.
We planted on another property today also adding a screen for the property owner. It is so dry right now that seeds have to be put down into moisture with minimal disturbance to conserve moisture. Sure could use about 2 days of slow drizzle around these parts.
/ Food Plot Screen
Update 05/28/12
It is dry here so anyone with some extra moisture can sure send some this way. Well checked on the EW screen today. Looks pretty good and can really row everything. Closer inspection reveals some sections where seedlings are just starting to erupt from the soil. Well either that or the deer are nipping off the succulent young seedlings. The little section is loaded with deer tracks so only time will tell unless we don't get any rain soon, then it probably will not matter much.
Here is a picture showing how the seedlings are growing and visible in the rows.
Here is a close up. If you look closely you can see the signs of stress already caused by lack of moisture in this area.
Praying for rain,
Dan
/ Food Plot Screen
UPDATE 06/09/12
Sprayed the screen yesterday with Atrazine. It has been so dry with no substantial ran since planting. The EW is looking good considering the lack of moisture.
Here is a close up showing the size most of the EW has gotten. If you look closely to either side of the ball cap you will see what is just beginning to grow to fill in the dead spots, more EW seedlings. Chalk this up to moisture, or more pointedly lack there of.
Dan
/ Food Plot Screen #10
Wow Dan, even though it's dry...it still looks really good. The lime really helps the 12-12-12 be absorbed in the soil.
We are getting rain down here in SC. Usually with the drought, it turns off by now and things go brown. This is a lucky year I guess and hopefully the corn crop will do well for once.
/ Food Plot Screen #11
Smallplot,
Is this screen primarily to improve access and egress by the hunter to the foodplot, or is it intended to cut off view for the deer to make them feel safer at the plot?
/ Food Plot Screen
Smallplot,
This location will afford all the above and more. The location was picked with years of watching deer cut the corner and cross the open corner of the field. The screen should alter movement to the safe side which also happens to be near 2.5 acres of alfalfa. Another benefit will be to block the view into the area from the roadway.
/ Food Plot Screen
UPDATE 6/24/12
With only two rainfalls of less than 1 inch since being planted this has turned out rather nicely so far. It has good deep green color so it is getting a good dose of N and going to town.
Here is a photo from the side. It is taller than the surrounding grass in the field.
And here is another photo showing how it looks taken a little closer.
And here is a photo taken looking at the end for a size comparison and to show how the Atrazine worked.
Dan
/ Food Plot Screen
Update 6/29/12
Grass mowed off and Screen is up and doing one of the jobs it was intended to do from the start.
Dan.
2023 Case TV450B (A62177)
2023 Case TV450B...
Used Landpride GR1525 Stump Grinder
Used Landpride...
2008 CM TRAILER 14' T/A ENCLOSED TRAILER (A65643)
2008 CM TRAILER...
iDrive TDS-2010H...
1991 FRUEHAUF 45'X96" FLATBED TRAILER (A65643)
1991 FRUEHAUF...
JLG E300AJ (A60462)
JLG E300AJ (A60462)
