Food Plot Maintenance... which herbacides
/ Food Plot Maintenance... which herbacides #21
Thanks. I've been fighting thistle for years with Roundup spot spraying, chopping them manually with a mattock and mowing. The neighbor on my east side never did anything with that pasture and their thistle will go to seed and blow all over the place. That property changed hands several months ago and the new owner did mow the field so that should help. 2,4-D unfortunately only works on the small rosettes. My other ten year struggle is getting rid of prickly pear, I had good luck with Surmount and then spot spraying for a few years but they are slowly coming back. Going to try a new herbicide called Mezavue (both are restricted.)
/ Food Plot Maintenance... which herbacides #22
Alot of the roundup NAME BRAND stuff has more than just glyphosate in it too. Like roundup quick pro or roundup concentrate plus has glyphosate + diquat. The roundup poison ivy / tough brush mixes in triclopyr. The roundup 365 or roundup extended control have both diquat and imazapyr to complement the glyphosate. Ortho groundclear is gly + imazapyr
So aside from just glyphosate or glyphosate + surfactant....there are some other types of herbicides that are sometimes mixed.
So if buying off-brand cheaper stuff.....make sure you are comparing apples to apples if you think one works better than the other.
And if you find one that you like and its expensive.....like roundup quick-pro that has gly + diquat......and you dont want to break the bank. Then buy generic glyphosate and generic diquat and mix your own version of "roundup quick pro" and you will save a boat load.
I feel like I'll be part mad-scientist when I get this all right :) My clover plots are starting to clear up, but some were far worse than others so either way a good test for the IMOX. My mix for around the house burns stuff down in days, and I'm still working on grasses, vines and broadleafs in my blue junipers.
/ Food Plot Maintenance... which herbacides #25
So if you HAVE to kill something try REMEDY its killed everything I've ever tried it on, even full grown huge trees! Used it on a 30" diameter Mesquite tree and it worked no problem!
Yes it will. Active ingredient is 2-4-D same active ingredient as Agent Orange.
Be careful applying this stuff - I wear more serious PPE, respirator and a light tyvek suit when applying this stuff with my backpack sprayer. Crossbow and Tordon RTU is similar with the same active ingredient, the tordon comes with the blue marker die. Nice bottle for dealing with cut stumps real quick - but like the others will kill all non grass vegetation when used according to the instructions.
/ Food Plot Maintenance... which herbacides #26
24D-B handles thistle quite nicely but it need to be mowed first. Stinger also works well but decimates alfalfa where as 24D-B won't. 24D-B is Butyrac which is the makers tradename.
All chemicals come with an application / MSDS sheet attached, it's Federal law. Read it, don't ask for opinions.
OP needs to spell it correctly, it's Herbicide not Herbacide.
/ Food Plot Maintenance... which herbacides #27
Actally, remedy has NO 24d. It is triclopyr.
/ Food Plot Maintenance... which herbacides #28
Good idea on the golf courses and farmers. I try to keep it mowed, but the clover is growing like crazy. Keeps growning over a foot tall, and unfortunately, the weeds also like the soil and sun combo.
Found an online place for Clethodim (not amazon) that wasn't as bad on shipping. I have a creeping bush for erosion on a slope near the house that I want to try it on. If that can prevent me from weeding it will be well worth it !!! Trying something called IMOX which is a blend of weed/broadleaf for the plots. It was a bit cheaper than buying both by themselves. We'll see how it goes. Maybe I can find a local place and save $12 bucks on shipping.
Seems like for perennials, it is cheaper to keep 'em weed free than to re-plant them so I'm giving it a shot.
Watch out for cheaper prices—frequently is a lower percentage of active chemicals ( in effect you are buying water). This is true in most herbicides and bug sprays when you buy from online places and big box stores.
Many of these chemicals are transportation regulated as are fluids for your tractor. If it can be shipped USPS, UPS, FEDEX, or other such carriers , it is not the stuff you want.
/ Food Plot Maintenance... which herbacides #29
To the OP, how did you plots look this fall after the IMOX? Takes a good 30 days to kill the grasses with IMOX. Broadleafs,... just kind of stunts them.
They cleaned up pretty good. They started looking like a lawn again. It did take a while.
2018 SPORTSTER BUMPER PULL (A60736)
2018 SPORTSTER...
Giyi GY-CYHC Mini QA Side Shift Forks (A60463)
Giyi GY-CYHC Mini...
2019 CATERPILLAR 259D SKID STEER (A62129)
2019 CATERPILLAR...
2011 WESTERN STAR  4900 SB (A60736)
2011 WESTERN STAR...
2015 MACK CXU613 DAY CAB (A59906)
2015 MACK CXU613...
2011 FOREST RIVER SIERRA CAMPER TRAILER (A60736)
2011 FOREST RIVER...
