Food plot, in a round about way...
   / Food plot, in a round about way... #1
teg
Super Member
nowhere
s
So kind of new to food plots... I had a tiller but my PTO cams would slip with it so I sold the tiller (instead of repairing the cams). In the trade I got a plow. Plan was (and no, I don't know what I'm doing) plow half then disk everything to see if plowing did anything useful.
View attachment 516240 View attachment 516242 View attachment 516241 View attachment 516239
Plowing went pretty easy. Sometimes went a wee bit too deep. It was a rough ride using the disks to level things out. I wanted to add extra weight to the disks to help them bite into the soil more so I mounted my Yard Tool on top and chained it down... easy 250 extra pounds. Love my grapple to be able to pick up all of my implements...
View attachment 516238 View attachment 516237 View attachment 516235
Final photo, the left side is Plowed and disked (the dark soil) right is just disked...
Plan next week is to disk again, rake. Might spray RoundUp again and wait two weeks before planting. Whitetail - winter greens.
   / Food plot, in a round about way... #3
The good thing about food plots is you can't really do it wrong. Just tear up the ground and plant your seeds. When do you actually plant your seeds there? Here, I wait until the end of September, which is when the heat breaks. If we get rain, I'll have a nice plot by the opener in November.
   / Food plot, in a round about way... #5
What is a PTO cam? I'm not familiar with that term.
   / Food plot, in a round about way... #6
Angle Iron frame Disc Harrows seldom have adjustable gang angles. If you had a box frame Disc Harrow the gang angles could be adjusted less aggressively for a second pass and the output would be a smoother seed bed.
I expect you appreciated the hydraulic Top Link when plowing.
I enjoyed your pictures. Interesting improvisation.
   / Food plot, in a round about way... #7
That harrow in the picture is adjustable all day long, the part that makes me nervous is the fact that it's not setting down and hitch pins secured in his Pat's quick hitch, and it should be, eventually if not corrected he will have a disaster. Maybe he just took the picture in the middle of hooking it up prior to using it.
....Maybe he just took the picture in the middle of hooking it up prior to using it.
Darn it, you got me... :D Guilty as charged. :ashamed: I did in fact noticed it before driving away (unlike my normal forgetfulness...)
I did think about taking another photo... but forgot :duh:
...When do you actually plant your seeds there?....
Usually any time in first part of August to mid-Sept. We normally get afternoon thunder showers enough to get it through the hot part of the summer. I plan to plant maybe half?? this weekend and throw out soybeans on the other half. Then the rest of it early Sept.
Coming into the front gate an young 8 pointer was eating under the apple trees... Saw him last year a couple times but never during the hunting season.
Also, yes this is disk is adjustable and not sure why I didn't think about setting it to a less aggressive setting.... :banghead:
2023 FORD F-650 SUPER DUTY CAB AND CHASSIS TRUCK (A59823)
2023 FORD F-650...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
1454 (A57192)
1454 (A57192)
2018 MQ POWER WHISPERWATT DCA-25 GENERATOR (A58214)
2018 MQ POWER...
TEST YOUR BID BUTTON! (A60429)
TEST YOUR BID...
2012 MACK GU (GRANITE) CAB & CHASSIS (A56129)
2012 MACK GU...
