3-Point Hitch Folded Lift Linkaged Scraped Backhoe Subframe
   / Folded Lift Linkaged Scraped Backhoe Subframe #11
Dale, you will need the Hose Kit found here: Access Page Click on Guest Login and then follow my link. Hose Kit From the CB65 parts book.
   / Folded Lift Linkaged Scraped Backhoe Subframe #12
Dale, you will need the Hose Kit found here: Login From the CB65 parts book.
OK... Thanks. Will have to find another way in as your link does not actually get me to a login. screen ...
UPdate:
Login
Next issue is what ports... Seems like the 2 short (650mm - 25 inch) come off pressure regulator (3PH) control valve assembly... Long one (1300mm- 51 inch) is enough to go to FEL control block.. WAG here....
Kind of get feeling that a hose from 3PH control block/pressure regulator to FEL port (P) is removed and "P" (from control block) is to BH (P) and "PB" from backhoe may go to FEL control block (P) ... OF course with no backhoe, a "loop" is required (quick connects just looped (male to female?))...
Think I'm getting closer...
Dale
2005 Peterbilt 387 with Wet Kit (A56435)
2005 Peterbilt 387...
Chevy caprice (A55758)
2021 Unverferth 432 Rigid 4 Row 36-inch 3PT Ripper Bedder (A55315)
2021 Unverferth...
2013 Ford Taurus (A56859)
2013 Ford Taurus...
2019 Harley Davidson Electraglide (A55973)
2019 Harley...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A55302)
Kubota SVL65-2...
