3-Point Hitch Folded Lift Linkaged Scraped Backhoe Subframe
/ Folded Lift Linkaged Scraped Backhoe Subframe #11
Dale, you will need the Hose Kit found here: Access Page Click on Guest Login and then follow my link. Hose Kit From the CB65 parts book.
/ Folded Lift Linkaged Scraped Backhoe Subframe #12
Dale, you will need the Hose Kit found here: Login From the CB65 parts book.
OK... Thanks. Will have to find another way in as your link does not actually get me to a login. screen ...
UPdate:
Login
Next issue is what ports... Seems like the 2 short (650mm - 25 inch) come off pressure regulator (3PH) control valve assembly... Long one (1300mm- 51 inch) is enough to go to FEL control block.. WAG here....
Kind of get feeling that a hose from 3PH control block/pressure regulator to FEL port (P) is removed and "P" (from control block) is to BH (P) and "PB" from backhoe may go to FEL control block (P) ... OF course with no backhoe, a "loop" is required (quick connects just looped (male to female?))...
Think I'm getting closer...
Dale
Rainbow Self-Propelled Volume Gun (A53317)
Rainbow...
JOHN DEERE 850K LGP (A58214)
JOHN DEERE 850K...
DSP 900 Balancer with Split Weight (A61307)
DSP 900 Balancer...
1993 East 39' Dump Trailer (A60462)
1993 East 39' Dump...
MAGNUM POWER PRODUCTS LIGHT PLANT (A60736)
MAGNUM POWER...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60352)
2020 Freightliner...
