3-Point Hitch Folded Lift Linkaged Scraped Backhoe Subframe
   / Folded Lift Linkaged Scraped Backhoe Subframe #11
Dale, you will need the Hose Kit found here: Access Page Click on Guest Login and then follow my link. Hose Kit From the CB65 parts book.
   / Folded Lift Linkaged Scraped Backhoe Subframe #12
Dale, you will need the Hose Kit found here: Login From the CB65 parts book.
OK... Thanks. Will have to find another way in as your link does not actually get me to a login. screen ...
UPdate:
Login
Next issue is what ports... Seems like the 2 short (650mm - 25 inch) come off pressure regulator (3PH) control valve assembly... Long one (1300mm- 51 inch) is enough to go to FEL control block.. WAG here....
Kind of get feeling that a hose from 3PH control block/pressure regulator to FEL port (P) is removed and "P" (from control block) is to BH (P) and "PB" from backhoe may go to FEL control block (P) ... OF course with no backhoe, a "loop" is required (quick connects just looped (male to female?))...
Think I'm getting closer...
Dale
2014 Ford Taurus AWD Sedan (A55853)
2014 Ford Taurus...
JOHN DEERE 6000 SERIES BRUSHGUARD (A57192)
JOHN DEERE 6000...
2015 KENWORTH T660 SLEEPER TRUCK (A58214)
2015 KENWORTH T660...
2024 Hydraulic Trencher Skid Steer Attachment (A55851)
2024 Hydraulic...
1989 BOMAG BW213D SMOOTH DBL DRUM ROLLER (A52707)
1989 BOMAG BW213D...
Deere 331G (A53317)
Deere 331G (A53317)
