foam-filled tires
   / foam-filled tires #1
BoFuller
Arizona
2008 Kubota L3400
I just bought a used telehandler and I know a few people that have one and they all have foam-filled tires. What are the pros and cons? And is something you can do yourself? I didn't write down the tire size, but the sucker weighs 26,000 pounds.
   / foam-filled tires #2
Bo, I'm guessing the biggest "pro" about foam filled tires is you never get a flat. You could drive screws into the tire and it would never go flat. The "con" is probably cost to have the tires filled and I'm guessing it's not a do-it-yourself project.
   / foam-filled tires #3
The last time I fooled with them was on Skid Steer tires, I don't think that much would be different on a TH. There were 2 types of fill, solid (new) foam, and "chunk" filled where they would fill it with as much used chunks, and then the rest with foam around the voids. As far as I know, the only down side is when a tire eventually wears out, the tire needs to be cut off and the wheel cleaned up. Me & a buddy did this and it was not too bad of a job. The chunk fill was cheaper. If you're working around the typ. const site, and after a few flats, and either paying for a service truck for a field repair, or taking that heavy mother off and hauling it to the tire shop.......... go with it. They (TH) are getting popular with the larger farms where I suspect this need is much less.
   / foam-filled tires #4
Bo
I am not sure there are any cons expect maybe cost. I had rear tires on my bx 2360 Foam filled. For weight and better tire wear. No flats, it cost my about $150 per tire. The front tires will cost $70 per tire. It's not something you can do yourself. Pros, no flats, better tire wear, you could cut right thought the tire with no effect, as far as your operation of the equipment. The tire will stay together. If you replace a foam filled tire you have To cut it off. I am sure there are benefits to the handling of the telehander with foam fill tires. in short you can rest assured, that you can drive, over anything that would damage a air filled tire. Causing you down time, and possibly money.
Brian
   / foam-filled tires #5
Do not do the chunky filled, the tires will go lax in no time, no support. What type of machine is it, Lull, JLG, Gehl, Skytrack, Gradall? 5k,6k,8k,10k,12k lbs? call OTR industries, or Solideal inc. They supply my company with 1000's of reach forklift(telehandler), skidsteer, Boom lift tires every year. Mostly they do exchanges, you purhase the tire already mounted, and give them back the "cores" (old tire and rims). If they do not have rims already for the unit, you must give them your rims, and they will mount the tires to them, turn around is typically 3-5days.
   / foam-filled tires
Gradall 534 C-9, 9,000 # lift, 40 ft
   / foam-filled tires #7
the only con I can think of is most manufacturers of tractors specifically say foam in the tractor tires will void their warranty
I do not know if it is ok with Gradall or not
Back 25 years ago when I was running plant maintenance, all our pneumatic tires would go flat every other week it seemed, so I had our tire vendor foam all of them, then after that I started spec'ing solid pneumatic tires
   / foam-filled tires #8
Stiffer ride. Heavy weight, so it is like having 4 big flywheels to get rolling and stop. Therefore, a little harder on the driveline and brakes.
No more flats. Multiple operators and I would do it.
If you are the operator maybe wait and see.
I have them on a articulating loader.
I have seen people running skid steers down to the thread and foam.
   / foam-filled tires #9
Most telehandlers list them as options including Gradall (which was purchased by JLG a few years ago)In fact they are pretty much standard issue now. I can't say exactly on price as I use national accounts, but you are probably looking at $800-$1000 per tire. Is that Gradall rear steer only?
   / foam-filled tires
It's a 1996 bought from private owner. I don't believe warranty is an issue here.
And the friends I know who have Gradalls are using foam.
UNUSED RAYTREE REDM32 - 32" EXCAVATOR DRUM MULCHER (A54757)
UNUSED RAYTREE...
11ft S/A Fuel Tank Trailer Frame (A51691)
11ft S/A Fuel Tank...
2016 Freightliner 114SD T/A 4,000 Gallon Water Truck (A53422)
2016 Freightliner...
2008 Dodge Avenger Sedan (A53424)
2008 Dodge Avenger...
2005 JOHN DEERE 310G BACKHOE (A50458)
2005 JOHN DEERE...
Informational Lot - Financing (A55218)
Informational Lot...
