Fluorescent light question
   / Fluorescent light question #1
Cliff_Johns
Elite Member
Northern Illinois
JD 4110
The double fluorescent light fixture in my garage has a failure. Both tubes light, but only at half (or less) brightness. Does that mean the ballast is bad, or does it mean one or both bulbs are bad? I guess I could replace both bulbs, but I rather not if the ballast is bad anyway.
Cliff
   / Fluorescent light question #2
Does it have a starter?
I don't understand the question. It's the type that plugs into a socket which is wired to a switch on the wall. I know nothing about the insides of a fluorescent light fixture except that they have ballasts that fail sometimes.
   / Fluorescent light question #4
Is there a small silver cylinder next to the ballast?
I don't know. I will have to pull it down tomorrow and look. I haven't tried to take it apart or anything. Do you think that might be the part that has failed?
Cliff
   / Fluorescent light question #6
Cliff
If its got one
   / Fluorescent light question #7
If it's the cheap fixture. you can buy new cheaper than replace parts. I replaced all my big bulb fixtures with the smaller bulbs T8?
   / Fluorescent light question #8
How much are T8 bulbs?
   / Fluorescent light question #9
Don't remember. Not any more than the T12 bulbs. Better lighting though
   / Fluorescent light question #10
Could be a starter. (if it has one) Most newer fixtures don't have starters.
Could be the ballast.
Could be the bulbs.
Change the bulbs. If that doesn't do it, buy a new fixture. You've already got new bulbs. :D
Seriously, a weak ballast can ruin the bulbs, and weak bulbs can fry the ballast. If you have to change the fixture, use new bulbs.
flooring (A55758)
flooring (A55758)
Deere 335P (A53317)
Deere 335P (A53317)
2022 Schulte 2500 Giant Rock Picker (A55315)
2022 Schulte 2500...
DOOSAN G25KW GENERATOR (A55745)
DOOSAN G25KW...
2019 KENWORTH T800 HOTOILER (A58214)
2019 KENWORTH T800...
John Deere 2640 2WD Tractor with 146 Front Loader (A57024)
John Deere 2640...
