Fluorescent light question
   / Fluorescent light question #1
Cliff_Johns
Elite Member
Northern Illinois
JD 4110
The double fluorescent light fixture in my garage has a failure. Both tubes light, but only at half (or less) brightness. Does that mean the ballast is bad, or does it mean one or both bulbs are bad? I guess I could replace both bulbs, but I rather not if the ballast is bad anyway.
Cliff
   / Fluorescent light question #2
Does it have a starter?
I don't understand the question. It's the type that plugs into a socket which is wired to a switch on the wall. I know nothing about the insides of a fluorescent light fixture except that they have ballasts that fail sometimes.
   / Fluorescent light question #4
Is there a small silver cylinder next to the ballast?
I don't know. I will have to pull it down tomorrow and look. I haven't tried to take it apart or anything. Do you think that might be the part that has failed?
Cliff
   / Fluorescent light question #6
Cliff
If its got one
   / Fluorescent light question #7
If it's the cheap fixture. you can buy new cheaper than replace parts. I replaced all my big bulb fixtures with the smaller bulbs T8?
   / Fluorescent light question #8
How much are T8 bulbs?
   / Fluorescent light question #9
Don't remember. Not any more than the T12 bulbs. Better lighting though
   / Fluorescent light question #10
Could be a starter. (if it has one) Most newer fixtures don't have starters.
Could be the ballast.
Could be the bulbs.
Change the bulbs. If that doesn't do it, buy a new fixture. You've already got new bulbs. :D
Seriously, a weak ballast can ruin the bulbs, and weak bulbs can fry the ballast. If you have to change the fixture, use new bulbs.
2023 FORD F-250 (A58214)
2023 FORD F-250...
JOHN DEERE TRACK TRACTOR (A54756)
JOHN DEERE TRACK...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Electric tri scooter irgc40 (A56859)
Electric tri...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
17201 (A55852)
17201 (A55852)
