Fluorescent bulb life
/ Fluorescent bulb life #21
JDgreen27,
Our house we built and moved into in 1/2005 has about 100 recessed fixtures that we filled with CF's. So far we have only had one burn out. We have undermount flourescent's in the kitchen that we never turn off.
I just did the math and they have been on close to 11,000 hours and they have not been changed. I'm sure they will now go out.... /forums/images/graemlins/shocked.gif /forums/images/graemlins/laugh.gif /forums/images/graemlins/grin.gif
Later,
Dan
/ Fluorescent bulb life #22
JDgreen27,
Later,
Dan
/ Fluorescent bulb life #23
my experience is that the life of a bulb is inversely related to the difficulty in replacing it.
/ Fluorescent bulb life #24
/ Fluorescent bulb life #25
I've found the same to be true with the smoke detector back up batteries. The ones that chirp at you when the battery begins to get low.
/ Fluorescent bulb life #26
/ Fluorescent bulb life #27
In 1985, the Hospital where I work built a new facility from the ground up. Nearly all of the lighting is T8 Fluorescent and many are never turned off... no on-off switches in the common areas.
A few bulbs were replaced in the first 6 months and then almost nothing for several years. The amazing thing is there are still a few original bulbs eleven years later.
/ Fluorescent bulb life #28
/ Fluorescent bulb life #29
Highbeam....I'm with you on the energy problem. I decided a few years ago, after getting myself into a 1989 total electric home, that I'd do everything I could to conserve electricity.
I bought a case & a half of FEIT 60 watt CF's which use about 14 watts of electricity. I stuck them in every fixture that would accept a CF and was amazed at how much my electric bill went down. I don't care what they look like as long as they do the job & save me $$. The 52 inch ceiling fans both have 5 CF's in them and a slight out of balance fan would go thru incandescent bulbs like crazy. The CF's stand up much better. I have had 7 failures so far....and replaced them from the origainl purchase (spares), and sent the defective ones to the manufacturer with a copy of my original receipt. I had replacements in hand about 10 days later...no questions asked.
My biggest electricity saver was when I installed a 220 Volt digital timer for the hot water heater. Being that I was working two jobs and only needed hot water at certain times of the day, that seemed like the thing to do. The original cost of the timer was around $100 but the payback period was just about 4 months....saving me aroung $25/month. Now I know that you folks out there with kids probably couldn't get by with something like that but living alone, I sure as heck could.
The refrigerator (1989 model) was relegated to the garage to be used for beer & soda after I decided to get a new energy efficient one. Not realizing how much power the old refrigerator used until I disconnected after closing up the pool. Power bill went down another $15 or so just by not using the refrig in the garage.
I guess I'm on a rant here...sorry about that. Anyone out there have similar energy saving stories or tips?
/forums/images/graemlins/blush.gif
Jon
/ Fluorescent bulb life #30
Jon
/ Fluorescent bulb life #31
heehaw,
Did you get those 130V bulbs at Lowes? I have 217 incandescnet bulbs and change several some weeks. I buy bulbs by the case, usually several cases at a time.
/ Fluorescent bulb life #32
heehaw,
/ Fluorescent bulb life #33
Jerry - 130 bulbs are dimmer than 120 if the same watts. Less light output from a cooler filament. For longer life from a conventional bulb you will lose light output or, for the same output level your electric bill will be higher. Check out the compact fluorescent bulbs.
/ Fluorescent bulb life #34
/ Fluorescent bulb life #35
i bought them at a local electrical supply, i changed to the cf before lowes came in, so i haven't checked to see if they have them or not, but the 130v bulbs sure stopped the frequent changing for me.
heehaw
/ Fluorescent bulb life #36
heehaw
/ Fluorescent bulb life #37
<font color="blue"> Check out the compact fluorescent bulbs. </font>
I would like to have them, but for the quantity that I would have to have they would be cost prohibitive.
/ Fluorescent bulb life #38
New/Unused Quick Attach Landhonor Hydraulic Winch (A65583)
New/Unused Quick...
KUBOTA L3940 TRACTOR (A64277)
KUBOTA L3940...
2018 KAUFMAN GOOSENECK TRAILER (A63290)
2018 KAUFMAN...
2001 Mack Grapple Truck (A64127)
2001 Mack Grapple...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
Adams 8 Ton Blender (A63688)
Adams 8 Ton...
