Fluids?????
/ Fluids????? #1
Carl1
Dayton,Ohio
IH 574 and IH424,Ih3414 loader
Bought a old tractor. in the process of changing fluilds. Can you use the same fluid in the tranny and fel??
thanks
/ Fluids????? #2
Carl,
I think we could all give you a better idea if you tell us what kind of tractor you have. Most newer ones use the same, in fact they use the same resevoir. But the older ones I can't tell you for sure.
murph
/ Fluids?????
Sorry,
IHC 3414 international loader built in the 60's
thanks
/ Fluids????? #4
Yes the 414 should use Hytran or the equivalent in both the loader and the tranny. I use the Premium UTF from Tractor Supply, as long as it meets the Hytran specs it should be fine.
I suspect you tractor uses a common sump in the tranny anyway, my 1968 2444 does.
You will have about 3 drain plugs on the bottom to pull, and possibly one on the rear of the lift box assembly, depending on your configuration.
2006 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2006 Ford F-250...
2025 SDLANCH Rachet Tie-Down Strap (A64194)
2025 SDLANCH...
JMR 8ft Man Basket Skid Steer Attachment (A64553)
JMR 8ft Man Basket...
1994 CHEVROLET GMT-400 EXTENDED CAB TRUCK (A65054)
1994 CHEVROLET...
2022 EZ-GO ELITE...
2016 Freightliner M2 106 S/A Day Cab Truck Tractor (A64194)
2016 Freightliner...
