Fluid Type
/ Fluid Type #1
zubin6220
I recently purchased a log splitter which calls for 9 gallons of hydraulic flluid. My question is - can I use the standard type that I use in my tractor? Thanks in advance.
/ Fluid Type #2
You mean like AW32 regular hydraulic fluid?
If so, yes. Even if it's tractor hydraulic/transmission oil it should be OK to use. The cylinder on your log splitter works the same as the ones on your tractor, IMO.
/ Fluid Type #3
AW-32 should be fine. Check your owners manual. If you are using it in 32 degrees or below, I would use ATF. In the forklift industry where they frequently use machines below 0 degrees and lower, they use ATF for hydraulic fluid.
/ Fluid Type #5
My log splitter called for ATF 22ton MTD (I don't used under 40f) -Ed
LOOK! (A63116)
LOOK! (A63116)
Land Pride BB1272 (A64126)
Land Pride BB1272...
2018 CHEVROLET SILVERADO 2500HD (A65643)
2018 CHEVROLET...
2017 Subaru Forrester (A62613)
2017 Subaru...
1990 FRUEHAUF 53' DRY VAN TRAILER (A64280)
1990 FRUEHAUF 53'...
Melroe 5525 Skidloader Backhoe Attachment (A65640)
Melroe 5525...
