Fluid level help
/ Fluid level help #1
marceldig
Outside New Orleans
Kubota L3000F
I just completed my 50 hour service on my L3000F. I followed the instructions in the owner's manual for changing the hydraulic fluid and drained all four plugs and removed and cleaned the strainer. As indicated by the manual, I refilled to the upper line of the indicator lens. I put in about 7 gallons (spec's indicate a 7.4 gallon fill), about 5 gallons in the front fill plug and about 2 gallons in the rear. I then started the engine and ran it for a few minutes and checked the gauge again. The lens indicated no fluid level, so I put the remainder of the 3rd 2.5 gallon bottle of UDT into the front fill plug, started it again, and still no level in the site glass. I added another ½ gallon, ran the motor for a few minutes, turned the steering wheel to activate the power steering, and raised and lowered the hitch a few times. Still no level in the site glass. I was unable to drive the tractor at that time, but my next step is to drive it around the yard a few times and check the level again. I also put all the used fluid into the same three 2.5 gallon containers, so I'm reasonable sure that there was about 7.4 gallons in the tractor before I drained it and the site glass indicated full. Am I missing something? Thanks for your help.
/ Fluid level help #2
Is it possible that it is overfilled? With all cylinders retracted on my tractor the oil level is above the lens and almost "invisible". A slight extension of the FEL cylinders will bring the level within the sight glass and make it easier to see.
/ Fluid level help #3
My guess would be the same as Glenn's. That stuff is clear and hard to see sometimes.
/ Fluid level help #4
Take a small rod, size it up from the refill hole down to the middle of the sight glass. That way you will know where the level should be on the rod. Then use the rod as a dip stick. Clear as mud. /forums/images/graemlins/crazy.gif
/ Fluid level help
You guys were right on! When I finished up last night, the lights in the old garage were not very good and the new fluid is considerably lighter than the old. This afternoon, I opened the garage door and sunlight fell across the lens, and sure enough, you could see the fluid plus there was a small air bubble at the top of the lens. I drained out about a gallon plus, cranked her up and everything was fine. Thanks all of you for the help.
/ Fluid level help #6
I'm glad to hear that there's no problem.
I don't really think it was necessary to drain out the excess oil, but I don't guess it hurt either. As I said, mine stays above the lens when all the cylinders are retracted but it's a geared tractor. Might make a difference if HST?? I don't really know.
/ Fluid level help #7
Does anyone have an electronic copy of the L3000F owners manual. I just bought a used one and they didn't have the owners manual. Thanks for the info regarding the hydraulic fluid levels as this is the reason for my checking this forum.
Thanks
2016 International WorkStar 7500 T/A Dump Truck (A61573)
2016 International...
Lucknow 360 Feed Wagon (A63688)
Lucknow 360 Feed...
2025 IRET13 Electric Tricycle (A64194)
2025 IRET13...
REDDICK OFFSET DITCHER (A63291)
REDDICK OFFSET...
2018 SHERP PRO1000 AMPHIBIOUS ALL TERRAIN VEHICLE (A63276)
2018 SHERP PRO1000...
2021 Harley-Davidson FLHP Road King Motorcycle (A61574)
2021...
