Fluid in tires
/ Fluid in tires #81
Me thinks the tocicity of antifreeze is way over rated.
It was suggested that it would kill off coyotes; did not work, antifreeze gone with my spring lambs.
/ Fluid in tires #82
there are published studies on the concentration needed to do harm, and ways to mitigate spills.
not rocket science by any means.
military has dealt with bigger spills than the private sector has seen in some time..
soundguy
/ Fluid in tires #83
soundguy
Soundguy, You continue to ride this dead horse. Why are you defending such a poor choice (ethylene glycol) of ballast in tractor tires?
Where are those studies that tell how to mitigate a spill of....say 55 gallons from a flat tractor tire in the field. Post one! ....and why would you do this when other safe, cheaper alternatives are available.
Lastly, what has the military vs private sector got to do with tire ballast?
Un-Soundguy advice abounds here. 25 posts by you on this topic. None of which is worth two-hoots in a tin-can.
Maybe you could spend more time reading and less time writing?
You cannot "win" with your position here. It's simply bad advice.
ROSCO SPR-H CHIP SPREADER (A59823)
ROSCO SPR-H CHIP...
Commercial Lawn Mower 652R (A56859)
Commercial Lawn...
Club Car Carryall Electric Utility Cart (A55851)
Club Car Carryall...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2004 Ford E-450 Jayco Escapade 28G Class C Motorhome (A61569)
2004 Ford E-450...
2016 AUXILIARY POWER UNIT (A60736)
2016 AUXILIARY...
