Fluid film
/ Fluid film #1
Soapandbacon
Cleveland, Ohio
Kubota BX25D
I've run across a few postings that mention something called fluid film. Can anyone elaborate on this product? Pros vs cons and what exactly is it for? Thanks , sorry if this is a stupid question ... Newbie here.
/ Fluid film #4
+1 on Fluid Film. Inhibits rust and it doesn't evaporate like WD40. Keeps metal looking shiny and new.
/ Fluid film #5
50/50 mix of acetone and ATF is also a good solution to rusty bolts and rust prevention. Much better than WD40 and similar products. Also.....much cheaper. Use it all the time in the shop.......I call it the miracle solution.:thumbsup:
/ Fluid film #7
I like to use fluid film on the shiny hydraulic cyl rods to protect them when long idle, and also I sometimes spray it on tools that may have gotten a bit damp.
/ Fluid film #9
I can honestly say, Fluid Film is good stuff. I don't ever plan on being without it.
James K0UA
/ Fluid film #10
Fluid Film is not a penetrant. It is a more of a rust inhibator and coating, or a lubricant. If you need a penetrant, any of the home remedies suggested are great, but they will not be as effective or hold up as long as Fluid Film will in its intended purpose.
Brian
/ Fluid film #11
I spray the underside of my truck every year going into winter. I also spray my plow quite often. I put a coat on any of the unpainted areas of the tractor pretty often too. LOVE me some Fluid Film!
ac
/ Fluid film #13
Brian
John Deere used fluid film to cover an entire cotton picker, preparing it for a long boat ride to Turkmenistan, which is a country in central Asia. It would shed off the salty sea water that would occasionally spray onto it while crossing the Atlantic ocean.
It must be good stuff to work in those conditions.
/ Fluid film #14
Great stuff...use it quite frequently and I always have one or two cans on hand.
/ Fluid film #17
Looks like another wonderful product/tool to add to my growing maintenance shed assets. I hadn't heard of this product and Googled an Aussie supplier... Sure enough, although it's not common down here, there is a supplier.
This should have many applications where I'm located as, on stormy days, I can hear the roar of the coastline surf. Which means that there will be a percentage of salt in the air and, being retired Navy, I well know the damage that can do.
Once again TBN & it's contributors to the rescue! :thumbsup:
Ta.
/ Fluid film #18
Looks like some AutoZone stores carry it.
I'll have to give it a try.
/ Fluid film #19
Kellsport Products offers all Tractorbynet members a discount . At checkout just enter the discount code 'tractorbynet" for a discount and free shipping on any order over $49.50
www.kellsportproducts.com
Please let me know if I can answer any questions about Fluid Film.
/ Fluid film #20
If it's good enough to get its own mil specs, it's good enough for our place.
No luck at my local AutoZone, so I took the TBN discount offer and sent in my order.
2019 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A69168)
2019 KENWORTH T680...
PALLET OF 51 X 41 X16 BRASS WEAR RINGS (A67714)
PALLET OF 51 X 41...
2017 Autocar Xpeditor T/A New Way 31ASL 31yd Side Loader Garbage Truck (A66736)
2017 Autocar...
2013 Dodge Avenger Passenger Car, VIN # 1C3CDZCB4DN759234 (A66738)
2013 Dodge Avenger...
PORTABLE OFFICE WITH BATHROOM (A67714)
PORTABLE OFFICE...
2015 DRAGON PRODUCTS CRUDE TRAILER (A67714)
2015 DRAGON...
