Flow divider PTO control valve
/ Flow divider PTO control valve #1
okfarmguy
Marlow, OK
1175 Case
I have a Case 1175, the PTO clutch pack was removed and taken to a dealer to have the clutch pack rebuilt. Upon reinstallation the PTO, three point lift, or the remotes will not work. With closer inspection it was discovered there is 3000# pressure at flow divider and no pressure exiting the flow divider. Removed the flow divider and rebuilt all portions with new o-rings, cleaned and lubricated all parts, used Scotch-Brite to insure there were no rough spots to hang, and replaced flow divider. Still, I have no pressure going thru the flow divider or the pressure release valve (obviously). As the lines from the pump were the only ones removed during disassembly, I cannot reason what could have happened to the flow divider, why it suddenly quit working, or why after disassembly and inspection it will not work again. Any information on these problems will be appreciated.
/ Flow divider PTO control valve #2
Could 2 hoses have been switched? That's quite a mystery, good luck with it. Let us know how it works out.
2016 Bobcat E85 Midi Excavator (A56857)
2016 Bobcat E85...
2025 Swict 84in Bucket Skid Steer Attachment (A61572)
2025 Swict 84in...
2019 CATERPILLAR 326FL EXCAVATOR (A62129)
2019 CATERPILLAR...
Rogator RG1300C (A63688)
Rogator RG1300C...
2000 Yale GLC030A 2,500lb Propane Foklift (A61572)
2000 Yale GLC030A...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
