Flow control For Tractor Mounted Log Splitter.
/ Flow control For Tractor Mounted Log Splitter. #1
Utopia Texas
Platinum Member
Brookshire & Cat Spring,Texas
Kubota B2650 / Kubota L6060 / Kubota ZD2300
On a previous Ford tractor I have owned there was a physical notch on the rear hydraulics handle where the lever could be set at a full flow position where one could use the open and close lever on a remote log splitter to actuate the cylinder. My Boomer 50 does not work this way and I have no way to set the lever on the side of the seat full flow to use a log splitter. How does one get around this? If I use a bungie strap to hold the lever open at the tractor seat and then used the lever on the log splitter remotely would this hurt the tractor hydraulics?
Thanks.....
/ Flow control For Tractor Mounted Log Splitter. #2
No, as the fluid is still flowing back to tank in a series flow.
Ofa Eko 8 studded tire chains
Ofa Eko 8 studded...
HOSE REELS (A68842)
HOSE REELS (A68842)
3145 (A63117)
3145 (A63117)
PORTA POTTY (A68842)
WACKER NEUSON  LTN8 LIGHT PLANT (A67714)
WACKER NEUSON...
2007 FRAC TANK 500BBL WHEELED (A68842)
2007 FRAC TANK...
