Flow control for backhoe stabilizers
/ Flow control for backhoe stabilizers #1
bobsphotos
ME
JD 3320 Ford 641 Ford 861 Kubota L3400
I would like to put inline flow control on my backhoe stabilizers so that when I bring them up, I can control how fast they come up so that I shock the rear end less. I tend to bring them up quickly and since my 3320 has an aluminum rear housing it makes me nervous.
Bob W
/ Flow control for backhoe stabilizers #2
You don't have to pull the control lever all the way open do you? Can't you just feather the flow and raise them slowly? :confused3:
I certainly can, if I remember. Flow control will take that issue out of the equation.
Thanks Brian, Have a link?
Bob W
/ Flow control for backhoe stabilizers #6
/ Flow control for backhoe stabilizers #7
+1. Nothing like learning how to use your equipment properly. Full time restrictors in these circuits will be a PITA.
/ Flow control for backhoe stabilizers #8
+2. It will add delay every time you raise or lower or adjust the stabilizers.. Major PITA potential.
/ Flow control for backhoe stabilizers #9
I do believe he said he wanted slow.
He apparently has tried the feather and doesn't like it.
/ Flow control for backhoe stabilizers #10
I would learn the feathering trick. Slowing it down so they dont "shock" the tires is going to be a PITA and painfully slow when you need to raise them the rest of the way up. My big BH has painfully slow outriggers. I hate it. Something about feeding a 4-1/2" cylinder with like a 1/4" line:confused2:
And I thought the 303x tractors were the only ones with aluminum rears??? I thought the 3320 was cast iron like most others.
1996 Great Dane 50' x 102" Reefer Trailer (A62613)
1996 Great Dane...
2005 MACK GRANITE CV713 T/A DUMP TRUCK (A64276)
2005 MACK GRANITE...
Bulldog 10000lb Jack (A63117)
Bulldog 10000lb...
John Deere 400 (A64119)
John Deere 400...
2022 Ford F-150 4x4 Crew Cab Pickup Truck (A61573)
2022 Ford F-150...
UNUSED (15) SDLANCH PROTECTION MATS (A64281)
UNUSED (15)...
