floor drain project
   / floor drain project #1
rdln
michigan thumb
jd 970, JD GT235
Hello, I have a tiling project to do in the laundry room, it is on a slab and this drain is currently there. I want the finished grout to be flush with a new brass grate, the kind that you see in a commercial kitchen or bathroom. As the picture shows its probably a female pvc glued on the top of a 2.5" pipeaw
   / floor drain project #3
In a bath shower stall, the drain is screwed in meaning the tile man can screw it up or downafter he does the mud bed and the tile so it is flush or just a tiny bit below the tile level. If you were to go to a Home Depot or Lowes or better yet a plumbing store they could show you the typical drain. If you see the drain then you understand. Then you could do some detective work to see what you have since no picture came through. http://www.zurn.com/operations/lightcommercial/pdfs/specsheets/fd2270.pdf
   / floor drain project #4
I have had to deal with that situation. If you get your new grate and take the old one off, you can see if the screw holes line up. If they do, take a piece of 3" pipe and make a spacer 1/4" or 1/2" or what ever the tile will be. Take some longer ss screws and screw the new grate on top of the spacer. Tile to it. If the hole don't line up, drill new ones,you may need concrete anchors.
2020 ASV RT-120 FORESTRY SKID STEER (A52709)
2020 ASV RT-120...
Mohawk 12,000lb Two-Post Electric Auto Lift (A55851)
Mohawk 12,000lb...
2001 TALBERT TRI-AXLE RGN TRAILER (A58214)
2001 TALBERT...
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58216)
SEMI AUTOMATIC...
excavator trenching bucket- one bucket per lot (A56436)
excavator...
2016 FREIGHTLINER CASCADIA (A58214)
2016 FREIGHTLINER...
