Float Valve
/ Float Valve #1
BratFarm
Kubota, Zetor, Ferguson, and John Deere
My Zetor is supposed to have a float valve (described in the owner's manual and verified by the previous owner). The lever does not detent when pushed forward. Do I need to adjust cables or just clean up the connections?
/ Float Valve #2
Under the bottom of the valve, there should be some caps/covers, covering the ends of the spool. Carefully remove them , inspect, clean, and lube. There is probably rust in and around the groove the balls set.
There are balls and springs under there, don't lose them.
/ Float Valve
Thank you sir, I will give that a shot when I build up enough courage to lie in the cold snow under the beast. Wish I had a taller barn door. Appreciate the warning about the jack in the box. You must have seen me work before.
2018 Bomag BC572 Articulated Refuse Compactor (A61572)
2018 Bomag BC572...
2020 ASV RT65 (A60462)
2021 UTILITY VS2DX 53FT DRY VAN TRAILER (A59905)
2021 UTILITY VS2DX...
2025 Swict 66in Bucket Skid Steer Attachment (A61572)
2025 Swict 66in...
2010 Sterling A9500 T/A Day Cab Truck Tractor (A61568)
2010 Sterling...
2023  FREIGHTLINER M2 22FT NON CDL BOX TRUCK (A59905)
2023 FREIGHTLINER...
