Float getting stuck
/ Float getting stuck #1
Donsyl
Central Arkansas
Cub Cadet 1811 \and a cub cadet 149
Ok ive been trying to figure this out for a while. I have a cub cadet 1811 and every now and then it sputters and i finally figured out it is the float getting stuck....what is the proper repair for this? is it a carb rebuild kit? or can i just get a new float pin? thanks Don
/ Float getting stuck #2
I was working on a B&S recently and I had to push and pull the float pin in and out until it worked free. Then I did the same on float so there was no binding. That fixed the flooding but there was more crud in the pilot tube that a few hours of soaking in lacquer thinner softened and cleaned.
thanks Jim i appreciate the advice......Don
/ Float getting stuck #4
did u ever figure out your float problem,i have some advice for u if u didnt
/ Float getting stuck #6
absoulutly it could be dirt, also does he use stabilizer off season,could be getting all gummed up,but i would start by spraying a little carb cleaner in it.
theres also other options depending more on the details of the care given to the tractor.keep bringing them
2010 ALTEC DIGGER DERRICK (A59914)
2010 ALTEC DIGGER...
16.5' Telescoping Ladder (A66408)
16.5' Telescoping...
2019 Mack Granite Tri-Axle Dump w/ Lift Gate 006043 (A62613)
2019 Mack Granite...
1999 Playbuoy Pontoon and Boat Trailer (A62613)
1999 Playbuoy...
EZ Flow Mod. 300 Gravity Wagon (A66408)
EZ Flow Mod. 300...
2019 DODGE RAM 1500 (A65643)
2019 DODGE RAM...
