Float (Detent) Not Working on L3130 Front Loader. Any Ideas??
   / Float (Detent) Not Working on L3130 Front Loader. Any Ideas??
Is it difficult to disassemble and clean? the "caps" that the ball bearings are under is on top on his loader valve. Hoping that is a blessing??
   / Float (Detent) Not Working on L3130 Front Loader. Any Ideas?? #12
   / Float (Detent) Not Working on L3130 Front Loader. Any Ideas?? #13
Spread a cloth under the assembly before you take it apart. Those little balls want to run and hide!
Fixed for now. Took off caps and filled with PJ lube for a couple hours. the spool for the "float still would not work. Swapped caps and it now works. Cleaned inside of caps and filled with grease.
Could NOT get the **** snap ring off the cap to disassemble and clean like I wanted. Wierd snap ring, beveled ends, no plier holes.
That is why I say "fixed for now"!
   / Float (Detent) Not Working on L3130 Front Loader. Any Ideas?? #15
WITTIG VACUUM PUMP (A50854)
WITTIG VACUUM PUMP...
100 GAL FUEL TANK (A50854)
100 GAL FUEL TANK...
2019 JOHN DEERE 317G SKID STEER (A51242)
2019 JOHN DEERE...
Kioti DK45 Tractor (A50860)
Kioti DK45 Tractor...
2008 INTERNATIONAL 4300 M7 SBA 4X2 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
