Float (Detent) Not Working on L3130 Front Loader. Any Ideas??
   / Float (Detent) Not Working on L3130 Front Loader. Any Ideas??
Is it difficult to disassemble and clean? the "caps" that the ball bearings are under is on top on his loader valve. Hoping that is a blessing??
   / Float (Detent) Not Working on L3130 Front Loader. Any Ideas?? #12
   / Float (Detent) Not Working on L3130 Front Loader. Any Ideas?? #13
Spread a cloth under the assembly before you take it apart. Those little balls want to run and hide!
Fixed for now. Took off caps and filled with PJ lube for a couple hours. the spool for the "float still would not work. Swapped caps and it now works. Cleaned inside of caps and filled with grease.
Could NOT get the **** snap ring off the cap to disassemble and clean like I wanted. Wierd snap ring, beveled ends, no plier holes.
That is why I say "fixed for now"!
   / Float (Detent) Not Working on L3130 Front Loader. Any Ideas?? #15
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A49461)
2016 Ford F-150...
72in Rock Bucket Skid Steer Attachment (A50322)
72in Rock Bucket...
Komatsu D39PX-24 Crawler Tractor Dozer (A49346)
Komatsu D39PX-24...
Delta Consolidated Fuel Tank 48000 (A51039)
Delta Consolidated...
1985 International X Con Semi (A50514)
1985 International...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A50323)
2009 Peterbilt 384...
