Float (Detent) Not Working on L3130 Front Loader. Any Ideas??
   / Float (Detent) Not Working on L3130 Front Loader. Any Ideas??
Is it difficult to disassemble and clean? the "caps" that the ball bearings are under is on top on his loader valve. Hoping that is a blessing??
   / Float (Detent) Not Working on L3130 Front Loader. Any Ideas?? #12
   / Float (Detent) Not Working on L3130 Front Loader. Any Ideas?? #13
Spread a cloth under the assembly before you take it apart. Those little balls want to run and hide!
Fixed for now. Took off caps and filled with PJ lube for a couple hours. the spool for the "float still would not work. Swapped caps and it now works. Cleaned inside of caps and filled with grease.
Could NOT get the **** snap ring off the cap to disassemble and clean like I wanted. Wierd snap ring, beveled ends, no plier holes.
That is why I say "fixed for now"!
   / Float (Detent) Not Working on L3130 Front Loader. Any Ideas?? #15
2014 UTILITY 53X102 DRY VAN TRAILER (A50046)
2014 UTILITY...
2015 Kenworth T400 T/A Vactor 2100 Combination Sewer Jetter Vacuum Truck (A50323)
2015 Kenworth T400...
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
1274 (A50490)
1274 (A50490)
RIGID TOOLBOX (A50854)
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
