fliiped tractor
/ fliiped tractor #21
If it has an oil bath air cleaner I would service it for sure- and check the intake tube for oil just in case
/ fliiped tractor #22
Glad your okay..whew.
Did the engine go high RPM's before shutting down?? if so contact dealer to be safe...heard some tractor are equip w/auto shut off when tip over.
/ fliiped tractor #23
Even though you have yours up and running, for general info.
I think you said your tractor was a shuttle shift,
a gear tractor can have the engine turned over by putting it in high gear and rocking the rear tires.
My method to roll over an engine on a shop floor or level driveway is to pull back on the tire then push forward,
repeat and you should be seeing the engine slowly bumping over.
Or gentle pulling with another vehicle.
Alternatively getting a socket on the front pulley works.
With a diesel just make sure your fuel cutoff is off, gas engine be sure and disable the ignition.
/ fliiped tractor #24
That is what the seat safety switch does..... shut off the engine.
/ fliiped tractor
The hand throttle was set to about 1400 rpms, no safety seat, so it ran for maybe 10 seconds before I shut it off.
INSPECTION (A65579)
INSPECTION (A65579)
2018 Bell B30E 30 Ton Articulated Dump Truck (A64194)
2018 Bell B30E 30...
PALLET FORK MOUNT SAFETY BASKET (A61572)
PALLET FORK MOUNT...
2026 DEVELON DX27Z-7 EXCAVATOR (A65053)
2026 DEVELON...
2022 EZ-GO ELITE...
Frontier Forks (A64127)
Frontier Forks...
