Fleetguard Antifreeze question
   / Fleetguard Antifreeze question #1
LouHill
Cincinnati, Ohio
John Deere 770
I am using Fleetguard Antifreeze with additives that I purchased at my local TSC store. I'm using it in a John Deere 770 diesel tractor (24 Hp). Can anyone tell me how often I should change this antifreeze. I understand the additives go bad after a while. Can I get by with changing the antifreeze once every two years? Thanks for your views on this matter.
   / Fleetguard Antifreeze question #2
You can have the antifreeze tested or get test strips I believe. However in that application I don't think there is a problem if you change it every 2 years.
Ben
   / Fleetguard Antifreeze question #3
Two years is about right but be sure to use only distilled water as the solute.
   / Fleetguard Antifreeze question #4
I would just replace the coolant. The tests strips are like $2 each I think, while the coolant is like $7 per gallon...
When I had my powerstroke diesel I only used strips to tests the SCA level. The freeze point etc was the normal way.
Thanks for your replies! I feel better knowing two year antifreeze changes are appropriate.
AUCTION STARTS HERE @ 9AM (A52705)
AUCTION STARTS...
2012 Club Car Carryall 1 Utility Cart (A54811)
2012 Club Car...
2017 FORD F250 SUPER DUTY EXT CAB SERVICE TRUCK (A53843)
2017 FORD F250...
2013 FORD F-150 XL EXTENDED CAB TRUCK (A51406)
2013 FORD F-150 XL...
2017 FORD F150 REG CAB LONG BED 4X4 (A54313)
2017 FORD F150 REG...
Forklift Safety Basket Attachment (A53421)
Forklift Safety...
